A friend of mine has a Stagea (GTR wagon) and after putting a new (R34) engine in it, it has developed a surge (from driveline) at light throttle (cruise). At the same time, it is giving too much drive (according to the torque split gauge) to the front wheels. Seems like it thinks the rear whells are spinning.
I'm not sure about the surge in the driveline at light throttle, are the tailshaft unijoints tight maybe?
As for front torque there really shouldn't be any unless you are either taking a corner hard or accellerating bloody hard so it sounds like something is wrong there. Is he using the same size wheels and tyres front to rear?
We are aware that it shouyld not have any torque going to the front wheels under the conditions that you describe. That is the problem. It's getting too much torque to the front wheels. When it is driven hard, the sterring wheel is just about being riped out of his hand.
Wheels are the same.
The surge and the torque split problem are one in the same.
Did he put in *just* the motor from the R34, or the front diff as well? As you are no doubt aware, R33 and R34 diff ratios are different - could explain the problem.
If the diffs are OK, I'd be checking simple things like tyre pressures and wear, and perhaps try rotating front to back.
How's the clutch? Maybe it's worn and somehow creating the problem? I know on gear changes torque seems to be directed to the front... I was experiencing the same problem you describe on 2 occasions: 1/when I had a dodgy clutch 2/ when my inner edges were scrubbed and the ECU thought tyres were rotating at different rates front:rear.
I had a similar problem with my GTS4 - it turned out the connections to the TPS were a bit suss. Make sure they are connected properly, maybe use a bit of contact cleaner on the terminals as well.
You should know what a TPS is - its not an item specific to Nissans, Toyotas have them too.
How is the wiring harness from the ATTESA controller to the transfer case? If there is a poor contact or broken wire you get this sort of stuff happening. Did you reset the ECU's before you started the engine? It may also be worthwhile getting one of Impakt's diagnostic displays (like a Nissan Dealer Consult) and checking out the sensors. The R34 engine sensors are slightly different to the R33's. Did you swap ALL of the R33 sensors (off the old engine) when you changed over to the new engine?
There are a few more things you can try, but I suspect one of the above will be the problem. :D
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
