Hey Guys,
Old thread here:
http://www.sau.com.au/forums/topic/446963-head-stud-torque-pushing-coolant-600hp/#entry7367800
Basically my 26/30 is still lifting the head, and it's just driving me absolutely crazy.
Some background info:
26/30 engine with CP 9:1 pistons. Was originally running a standard nissan 26 HG, and rb25 ARP studs the non ARP 2000 type. Was running 98/Toluene and made about 500awhp. Went to get it dyno tuned again, and started to get pretty bad knock on the dyno which was attributed to the high comp, switched to E85 on the dyno, and ended up making 620awhp running very well. It did however start to lift the head on the very last pull. Despite this got it back, and it ran well for quite some time with no issues. Went to a track day a few months down the track, and after the day had ended noticed it was pushing coolant (a lot more), but still ran well despite this.
Fast forward and the issue became worse, to the point where it would start to break down at WOT which it had never done previously. Pull the head off and went a tomei 1.2mm HG with ARP 2000 head studs, ran fine again for a while and issue returned. Now the head had been faced previously, and upon installing the tomei HG I did not have the head faced, the face looked very good still, and had previously been running the old composite gasket, I just cleaned the face and removed any old gasket prior to installing. When this issue returned I put it down to not having the head faced, which was a oversight on my part.
So pulled the head off again, and took it in to be checked, had the clearances re-done whilst it was in, pressured tested as well and had it faced. Re-installed again using the old tomei HG using copper coat, cleaned all the coating off the tomei HG using gakset stripper prior to installation.
Re-torque head studs to 105ft/lb, used the ARP lube on head stud thread (both ends) and under the nuts themselves. Issue has returned again as of yesterday, it was bubbling up through the rad just on idle, will drive fine off boost but any boost and it breaks down pretty bad, so it's HG again.
I almost at my wits end.
Now it cold comps with a standard HG at around 200psi. So should I be using a greater clamp pressure then 105ft/lb? Should I re-drill the block for 26 studs instead? Could the block possibly be warped, and is it possible for this to occur?
ARP have a part number specifically for the 26 and 25/30 conversions now, does anyone know what the difference is between this and 25 studs?
Also someone recommended running dual washers, to stop them bottoming out on the studs, can anyone verify that they have also needed to do this? When I torqued the head, I went back to 0 again and none of the nuts had bottomed out, so I didn't end up doing that. Also I hadn't heard of anyone else having to do this out there.
Any thoughts, comments whatever, throw them at me.
https://www.sau.com.au/forums/topic/457787-rb2630-lifting-head-need-help/
Have you pulled the plugs to check for water ingress?
Is the water level actually dropping?
Are you 100% positive that your RPM breakdown is a head gasket or are you jumping to that conclusion? (I seen heads get pulled off before where it wasn't the head gasket at all)
If all else fails and it is the head gasket, something will be warped or the deck finish on either surface is too rough.
Could also be in the tune, E85 is good at taking timing and boost however at those cyl pressures less knock will be more damaging as its at higher pressures.
The possibilities are endless. Anything from the block needing a skim too, all the way through to the head being soft from having been cooked at some time in the past. I think you may need to give up on trying to guess which bandaid to apply and dismantle it properly and give the bits to someone who has the right tools to answer those questions.
Yeh I thought it was spark so swapped out the plugs/ignitor/packs, made no difference. Then took it for a run yesterday, was breaking down under boost really bad. Let it cool down then took the cap off, started it without the cap and it was just bubbles everywhere.Yes water level was also dropping.
So the only solution is to pull it all down and remove the motor? Surely there is a way I can check things like a distorted block in the car with the head removed?
I run 2 washers on mine, never had issues, re-used old mls headgasket a few times not a problem. My studs are 8 years old and been used a few times aswell. Im only tensioning to 80ft lb
If u look the thread finishes just below one washer level, i think this could be your issue.
Edited by sky30
  • Like 1
OK cool thanks sky30. Why did you end up running dual washers?, did notice it was going to be close, or did you have some bottom out on you?
Cheers.
  • Like 1
Since you have gone to the trouble of lubing your studs at both ends you can be sure they have bottomed out in the block so an extra set of washers is so simple and cheap - definitely worth a try. But as you may have blown your H/G you will have to remove the head once more to check.
It's currently running 25psi and making 620awhp. I would love to just keep it at that, but with the head staying on, lel.
Maybe my issue has been the washers all along. Has anyone successfully re-drilled for 26 studs with the block still in the car? I read somewhere that the counter bore is done first, then drill out the main thread to 10.5 and tap. That's all fine, but doing it all square is my main concern.
it would be possible.
Try and find someone with a mag drull (magnetically mounts and I'd set square).
Make sure you tape up everything except the holes to be drilled.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
