Ok first a bit of history
I bought the car in 2003 it came with the usual exhaust and pods and beyond that was pretty much standard, i replaced the fuel pump and had the factory ecu remapped and made a respectable at the time 235kw at the wheels
In 2004 I sold the car and stayed in contact with the new owner, come easter 2007 the owner decided he wanted to part with it and after a check over the deal was done.
Over the next few years it stayed basically mechanically the same but got fitted with a set of r33 brembos and a new set of wheels DSCN0097.jpg
In 2011 the engine finally let go and after dramas with the engine builder I lost interest in the car and it sat outside, untouched for about 3 or so years. Eventually I bought and fitted a stock r33 engine, removed the hicas and fitted another set of wheels BE45199B-21D6-4332-A0D8-DFF69E14B8B2-334
So here we are today and I've finally decided to do a build but won't be anywhere near as big as the previous one was. The goal for this build is to make 373kw (500hp) at the wheels with as close to standard response as possible
Now on to the build
First things first after sitting around for so long, with my little helper I replaced all the oils in the car 38715BAD-0206-4564-8071-EAA643FC9322.jpg
Then took it up to jez for a baseline run so that we know where I'm starting from and know how far I need to go8DDD7264-F675-4601-8890-6964AD4070D8.jpg
So here we are with the baseline and a plan in place that I will reveal as the build continues
  • Like 5
https://www.sau.com.au/forums/topic/458011-r32-gtr-long-term-love-now-project/
I'm going to try and keep the updates weekly in order to stop the thread/build going stale, not everything will be a performance upgrade, there will be some general refreshing and tidying up as well. But there will be photos and information of everything that gets done along the way
This won't be a do everything in one hit build, it's also not going to be a slap a bunch of crap together and hope for the best. It's going to be a very thought out and have a few things a lot of people either wouldn't do or wouldn't think of
TBH it's very hard to find info on E85 and -7's.
i just said stuff it and we will find out. Tuner thinks 350-360 on E85 and they will run out of puff. Will report back when she is finally fixed though. Can't wait to see what you will do man!
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
