the reason for the purchase of Santas little box it to take advantage of the haltechs capabilities and the first thing out of the box is this little puppy
0509C321-1676-4480-964A-0CD4F88B422A_1.j
And today I finally fished installing it, I put the sensor under the car 35E4F973-243B-4BB7-8B24-BA82EEE946CD.jpg
(There is a bracket now and the wires covered)
And ran the wires into the car, to the passenger side, under the seat, into the I/0 box and then the can hub
I still need to mount them properly but I may still have a bit of fiddling with them so will do it later
Next is the wide band oxygen sensor kit sat the control module in a similar a lot to the I/O box
0305118B-7B5C-423E-9626-F34C09CCA9E5.jpg And ran the wire through where the cat temp sensor use to run
Haven't hooked it up yet as the new exhuast hasn't been fitted yet
And basically under my carpet now looks like this mess
The day finally came, we fitted the exhaust and what a mission that was, because I wanted the big center muffler fitted to it we ended up custom making the entire center section
We started with this eye sore and was part of the reason I wanted the exhuast changed as it never fit right to begin with and had a restrictor in the center muffler
So we got that off and first fitted to new front pipes and welded the bung for the wide band, welded the flanges on the cat and fitted it
And the reason for changing the center muffler
Replaced with this magna flow muffler
I didn't get any photos of the middle section it was hot and we wanted to get out of there
But here it from the back after being finished
And back on the ground
And here is the where the wiring runs for the oxygen sensor, it has brackets the hold it to the rail now but they aren't in the photo
Over all it has a nice deep note, it still fairly loud without being obnoxious and despite not giving it a boot full due to not having the tune checked you can feel the turbos are more keen to wake up
  • Like 1
Oh I forgot to mention that while we were doing the exhuast i decided to check the health of the limited slip diff and well...... It doesn't do a dam thing, I was able to grab to 2 rear wheels and turn them in opposite directions without any resistance at all
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
