2 hours ago, admS15 said:
Which is why 8374 makes sense. Isn't that right Grant??
Na, twin EFR's is better.
Cos it's one more than one hey Bill?
  • Like 1
2 hours ago, r32-25t said:
That kit is far to untidy,
Wrap the bonnet with a photo of stock engine bay, that way you'll look at it and say "that's tidy engine bay" :P
Sent the rocker cover out to craved coatings and got it done to match the rest of them IMG_4744.thumb.JPG.6afa6134301a3d4fee17e346f645c60a.JPGam going to uncover the writing on it due to the candy looking different there compared to the rest
  • Like 1
Did some work on it over the weekend, fist pulled the timing belt off and inlet cam cover off
and new cam in for clearence measuringIMG_4811.thumb.JPG.d6fef983e41a59b5e176ea8d2d79bc1e.JPG
6 of the clearances are out of spec and the shims have been ordered and should hopefully be here in the next couple of days
  • Like 1
Parts are back from ceramic coating IMG_4822.thumb.JPG.5cf3f8ee475476153faf90d50043a1e0.JPGi also bought plugs for the original oxygen sensors because I no longer use them and they will just be in the way when installing the turbos
  • Like 3
Had a couple of hours over the weekend to work on itIMG_4827.thumb.JPG.3af7f04e2cb1aed102f7d208a5971def.JPGthe shims had arrived a few days before an i fitted them, checked the clearances were spot on
IMG_4828.thumb.JPG.3db9bfcd9c9a8326e7ccd08c1287e64e.JPGthen moved onto the cam gears and timing belt
  • Like 3
I then grabbed a die grander with basically a scotch bright pad on it and attacked the powder coatIMG_4833.thumb.JPG.7f2c88345b2389c350619f4fe737f249.JPG halfway done
IMG_4834.thumb.JPG.2353981157b2bd15f90050fd90bca345.JPGpowder coat gone and then I ran another pad over it to give it a machined look
IMG_4835.thumb.JPG.7c791d0e52471563868b131866efcdd9.JPGand the finished product
  • Like 1
Then got to fitting it to the engine IMG_4836.thumb.JPG.04867ea540bf3c0762a2b3f6934ce1f5.JPGhere it is fitted to the engine
IMG_4837.thumb.JPG.df0c7aade7b3e1f6dac59e3e349b01ce.JPGthis comes with the kit and of corse is the reason the kits costs so much lol
IMG_4838.thumb.JPG.a9df0418147d17669701275a29de6702.JPGand with all the sensors and oil cap fitted,
Had some time today so I decided to spend it playing with the car IMG_4822.thumb.JPG.d009be87cb63945f4e5725c08b67dc90.JPGIMG_4844.thumb.JPG.5f6d12c7e23b38252856bef4d6e73724.JPGfinally unwrapped all the parts I got ceramic coated, it's a shame you won't see them once they're installed
And finally the turbos can start going on, some people will be a bit disappointed IMG_4824.thumb.JPG.28e6ae604b5f998129b74c4849a2e97a.JPGIMG_4823.thumb.JPG.f5c51bbaee14e0635d24ed4146f4b0bc.JPGbut I'm staying twins (that was never a secret) and they are nothing specialIMG_4825.thumb.JPG.b6560843efd7188c06aba5905a80ef37.JPGjust a basic set of -5s with very low kms that I got for a price way to good to pass up
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
