2 hours ago, admS15 said:
Which is why 8374 makes sense. Isn't that right Grant??
Na, twin EFR's is better.
Cos it's one more than one hey Bill?
  • Like 1
2 hours ago, r32-25t said:
That kit is far to untidy,
Wrap the bonnet with a photo of stock engine bay, that way you'll look at it and say "that's tidy engine bay" :P
Sent the rocker cover out to craved coatings and got it done to match the rest of them IMG_4744.thumb.JPG.6afa6134301a3d4fee17e346f645c60a.JPGam going to uncover the writing on it due to the candy looking different there compared to the rest
  • Like 1
Did some work on it over the weekend, fist pulled the timing belt off and inlet cam cover off
and new cam in for clearence measuringIMG_4811.thumb.JPG.d6fef983e41a59b5e176ea8d2d79bc1e.JPG
6 of the clearances are out of spec and the shims have been ordered and should hopefully be here in the next couple of days
  • Like 1
Parts are back from ceramic coating IMG_4822.thumb.JPG.5cf3f8ee475476153faf90d50043a1e0.JPGi also bought plugs for the original oxygen sensors because I no longer use them and they will just be in the way when installing the turbos
  • Like 3
Had a couple of hours over the weekend to work on itIMG_4827.thumb.JPG.3af7f04e2cb1aed102f7d208a5971def.JPGthe shims had arrived a few days before an i fitted them, checked the clearances were spot on
IMG_4828.thumb.JPG.3db9bfcd9c9a8326e7ccd08c1287e64e.JPGthen moved onto the cam gears and timing belt
  • Like 3
I then grabbed a die grander with basically a scotch bright pad on it and attacked the powder coatIMG_4833.thumb.JPG.7f2c88345b2389c350619f4fe737f249.JPG halfway done
IMG_4834.thumb.JPG.2353981157b2bd15f90050fd90bca345.JPGpowder coat gone and then I ran another pad over it to give it a machined look
IMG_4835.thumb.JPG.7c791d0e52471563868b131866efcdd9.JPGand the finished product
  • Like 1
Then got to fitting it to the engine IMG_4836.thumb.JPG.04867ea540bf3c0762a2b3f6934ce1f5.JPGhere it is fitted to the engine
IMG_4837.thumb.JPG.df0c7aade7b3e1f6dac59e3e349b01ce.JPGthis comes with the kit and of corse is the reason the kits costs so much lol
IMG_4838.thumb.JPG.a9df0418147d17669701275a29de6702.JPGand with all the sensors and oil cap fitted,
Had some time today so I decided to spend it playing with the car IMG_4822.thumb.JPG.d009be87cb63945f4e5725c08b67dc90.JPGIMG_4844.thumb.JPG.5f6d12c7e23b38252856bef4d6e73724.JPGfinally unwrapped all the parts I got ceramic coated, it's a shame you won't see them once they're installed
And finally the turbos can start going on, some people will be a bit disappointed IMG_4824.thumb.JPG.28e6ae604b5f998129b74c4849a2e97a.JPGIMG_4823.thumb.JPG.f5c51bbaee14e0635d24ed4146f4b0bc.JPGbut I'm staying twins (that was never a secret) and they are nothing specialIMG_4825.thumb.JPG.b6560843efd7188c06aba5905a80ef37.JPGjust a basic set of -5s with very low kms that I got for a price way to good to pass up
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
