28 minutes ago, r32-25t said:
I had every intention of doing just that but i cant find the original bolts for the gearbox crossmember
Another kudos order, I actually have a spare Speedo drive. But new is always better
4 minutes ago, Robzilla32 said:
Are they still at the zinc coaters?
When you fit the getrag you need 10mm spacers on top of the gearbox crossmember and I needed bolts that were 10mm longer and I’ve misplaced the originals cause of moving house
I’m thinking of trying skyline spares to grab a second hand set
Nice, that's the way to do it! I watched another video where PPG just sent the centre section and the owner had to make a few mods to the housings to make it all fit. Admittedly it was in the States so a costly exercise to send housings over just to have them shipped back again!
I’ve seen that video and it is an option to do, ppg charge to fit the gear set for you but I like the idea of if it wrong I can send it back and get it corrected
Couldn't agree more. Its not worth stuffing around with for that sort of money! Speaking of which, how much did it cost all up? PM me if you'd prefer.
Can't wait to see vids of flat shifts at 9k rpm!
Getting there, I get mine back next week, we should plan a cruise down south, but you’ll have to drive slow so I can keep up.
the sequential makes a huge difference, you will love it!
  • Like 1
Nice bet you’re look forward to getting it. Yeah we should go for a drive and I won’t be able to drive fast cause of the engine pushing water still
Looking good, can it be driven yet?
Did you unstitch the boot? I would have given you mine, the one I used with my PPG.
Who is setting up the flat shift for you?
it can be driven, just wont have reverse lights or anything else electrical hooked up
the boot was already unstitched from having the getrag in it before
probably will be jem cause they tuned it last time
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
