I run these in my shit box, seen plenty of track days, skidpans, 8k RPM launches, etc. with the first 2x motors.
https://www.vibra-technics.com/nissan/skyline_r32_r33_r34_gt_gtr_gts_t/623/NIS240M_kit/engine_mount_r33_gts_t_rb25det_r34_gtt
And you guys know, I thrash my car when I can at the track.
Still using the same mounts, some slight vibration but nothing like a car with solid urethane ones. I get a bit of a rock with the idle braps too, extra hard c()nt at the lights.
Might be worth putting in better engine mounts(?), sounds like the stock OEM Nismo branded ones might tear with all the powahs.
 They are labeled wrong, a gtst mount and a gtr mount are completely different
Started installing the inlet manifold
put the first part on along with the drive by wire motor
then the throttles and adjusted rod for the throttles
then the new nismo plenum went on, I didn’t take the lugs off because I like the original finish
  • Like 8
22 hours ago, r32-25t said:
also fitted an oil pressure regulator against the block under the manifold
If it's an opr40, oil feed in and turbo out lines are backwards - it matters on these, it's not a fuel reg where the top 2 side ports are common inlets.
1741931481_Screenshot_20221009-122437_AdobeAcrobat.thumb.jpg.00ddaba2f8f4f6e0d370c4dfef5a1716.jpg
  • Like 3
Ok thanks glad someone picked that up, I didn’t read in the instructions and just assumed it didn’t matter. Will fix it up before I put the engine in
  • Like 3
No worries, you can just rotate it 180 but your gauge port will be unusable obviously pointing towards the block.
All good I’m not putting a gauge in it so won’t be an issue
made all the sensors fit so that the ecu knows what going on and will also allow the factory dash to be retained
built all the scavenge lines, it has 2 from the sump and one straight out the back of the head. Also has a water line from the back of the head to the water neck that the top radiator hose attaches to
engine ready to be dropped into the car
  • Like 2
By having a scavenge line from the head to the pump, doesn’t that take away from what yours trying to do? You have two points in the sump which would be “pulling down” then one at the top of the engine sucking. Kinda like a push and pull situation going on instead of all pull.
  • Like 1
On 23/10/2022 at 7:01 PM, r32-25t said:
All of them are pulling which creates a vacuum in the crankcase, unless Porsche have been getting it wrong since the 60s
Nah man, Porsche have been doing it wrong for decades 😂😂😂
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
