the reason for the purchase of Santas little box it to take advantage of the haltechs capabilities and the first thing out of the box is this little puppy
0509C321-1676-4480-964A-0CD4F88B422A_1.j
And today I finally fished installing it, I put the sensor under the car 35E4F973-243B-4BB7-8B24-BA82EEE946CD.jpg
(There is a bracket now and the wires covered)
And ran the wires into the car, to the passenger side, under the seat, into the I/0 box and then the can hub
I still need to mount them properly but I may still have a bit of fiddling with them so will do it later
Next is the wide band oxygen sensor kit sat the control module in a similar a lot to the I/O box
0305118B-7B5C-423E-9626-F34C09CCA9E5.jpg And ran the wire through where the cat temp sensor use to run
Haven't hooked it up yet as the new exhuast hasn't been fitted yet
And basically under my carpet now looks like this mess
The day finally came, we fitted the exhaust and what a mission that was, because I wanted the big center muffler fitted to it we ended up custom making the entire center section
We started with this eye sore and was part of the reason I wanted the exhuast changed as it never fit right to begin with and had a restrictor in the center muffler
So we got that off and first fitted to new front pipes and welded the bung for the wide band, welded the flanges on the cat and fitted it
And the reason for changing the center muffler
Replaced with this magna flow muffler
I didn't get any photos of the middle section it was hot and we wanted to get out of there
But here it from the back after being finished
And back on the ground
And here is the where the wiring runs for the oxygen sensor, it has brackets the hold it to the rail now but they aren't in the photo
Over all it has a nice deep note, it still fairly loud without being obnoxious and despite not giving it a boot full due to not having the tune checked you can feel the turbos are more keen to wake up
  • Like 1
Oh I forgot to mention that while we were doing the exhuast i decided to check the health of the limited slip diff and well...... It doesn't do a dam thing, I was able to grab to 2 rear wheels and turn them in opposite directions without any resistance at all
