You are flirting with danger modifying the Injector settings without a wideband.
The fact the coolant temp appeared to drop would mean the ecu would add fuel, probably the problem all along.
No way did the settings in the ecu change by themselves.
Thats the thing, when I drove it last night nothing had been changed by me. How can the tune go from being fine for months and then all of a sudden be really rich?
Spoke to a workshop in adelaide and he suggested that is has a currupt file. It's getting tuned in 3 weeks so that should clear that up.
Edited by fmlycar
or your water temp sensor is cactus... potentially accessing enrichment values from the water temp correction table...
buy a wide band already, it's cheaper than a new motor.
  • 1 month later...
Im also on the missfire spluttering chain atmo
Brand new spitfires
Brand new coil loom
Brand new z32
Now its time to look on fuel side of things
Pumps are only 4 years old used like 25 times
Could be fpr
Need to get a fuel pressure Guage
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
