What a great day indeed!!! my first DECA is hopefully the start of more to come!!!
Big big thanks to the SAU Vic DECA crew - Bec, Ryan, Leon and Wayne (if there are more thank you too!)
Also thanks to all the people who helped on the day, things like this wouldn't be possible without people like you :P
And last but not at all least thank you to those who were competing, hope you had a blast and that we will see you all for the next one :)
  • Like 2
Had a great day out, tag teaming in the little red mx-5 with Jack. Just wanted to offer my thanks and appreciation for those who volunteered today. It's often a thankless task and without you guys it would not go ahead..so thanks a heap!
P.S whats the std timeframe for timing results?
Jarrard
  • Like 2
Anyhow here is my videos off the skidpan
Group1 is the first group on skidpan
Group1 is the 2nd group on skidpan surprise surprise
battle1 and battle2 the 2 sessions in the arvo.
usual rules apply
if you upload to social media eg youtube facebook so on please tag SAUVic and myself EMTS
(this is our advertising for the next one so if you want to keep them running....)
if you want to use for any commercial purpose please contact myself.
  • Like 1
Another great weekend. I'm sure everyone involved in reviving deca would agree it was worth it! Always good to catch up with everyone, was also great to meet a bunch of new people.
Big thanks to all our volunteers on the day. Massive thanks to Wayne for organising all our helpers and spending the whole day out on the skid pan.
Great work Odi with the online entry system. It has certainly made entering a whole lot easier!
While its unfortunate your car broke Martin, its great to have footage from the day! Looking forward to seeing some photos from the camera guys getting around.
There are a lot of people who have helped out with deca and make it the fun event it is. Your help is appreciated.
See you all at the next one.
https://youtu.be/Xrw36bSZni8
  • Like 2
Also should have some cool drone footage from Tony on the way :)
Thanks Martin for the camera work.
And a massive thanks to Bec, Ryan, Leonica and all the volunteers for organising and running the day! Had a blast as always.
Note to self: avoid midgets at the pub, it doesn't end well
  • Like 1
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
