lol even open I have to maintain a constant lean towards the centre just to fit - makes motorsport difficult :(
The 86 was much easier to pilot, could actually sit up straight albeit still slouched
  • Like 1
A vid I whipped up last night (this morn :/ ). May have gone over board with a music track and all but why not, please watch till the end or at least the end :)
Great video tony!
Lol the end was me attempting to do helis but the evo just kept gripping in 1st and pulling itself out of the spin (or bogging down in 2nd). Finally managed it during an expression session at the end of the day complete with a smoke show :D
  • Like 2
DECA was awesome as it was in years gone past. Thanks to Ryan Leon and Bec for working hard behind the scenes to make DECA a possibility again. They have gone over and above to get it done and it's much appreciated.
Thank you to all those who volunteered on the day to time, film, marshal set up and clean up including Wayno, Anna, Trent, Martin, Tony, Robyn, Liam and anyone else I missed. No skids without these people!
For the people that are unaware the DECA facilities required some improvements to enable the events to be insurable. Only 2 car clubs put there hands up to volunteer to make the improvements one of them being SAU. Which really shows the kind of club/community this is. For those that drove to Shep and put in the hard work just for the possibility of SAU DECA events returning it's all been worth it as DECA is back!!
[emoji594][emoji100]
  • Like 2
Great day and weekend guys and gals. Thanks to all involved for organising as well as all the volunteers.
Can't wait for the next one.
Pretty happy with results. Less air and some better rears will help next time (zomg ALLLLLL the spins on that wet skidpan). Haha.
My videos will be up soon, will take SAU and the like to get the word out there.
Also should have some cool drone footage from Tony on the way :)
Thanks Martin for the camera work.
And a massive thanks to Bec, Ryan, Leonica and all the volunteers for organising and running the day! Had a blast as always.
Note to self: avoid midgets at the pub, it doesn't end well
Bahahahahaha second that midget at a pub theory
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
