want to run street class for nats,
then the power comes, usual bolt ons fuel system, turbo AFm and cams, E85 tune easy 300.
but want one more trophy first...
let me know if you need anything... got lots of stuff lying around and will have a shit load more once wiring is finished.
got 2x Z32 AFMs here. got a oil filter relocation kit too. lots of leftovers from 2x gasket kits, not all will fit yours but most should.
thanks for that, will touch base when start my shopping list.
just glad that mechanically and drivetrain/suspension now to the same point as prior to crash.
seat and diff next, then work on cosmetics as I collect power parts.
hoping this time next year it a wide body 300+kw car. with a hundred kg or so less weight
feels good to have a project moving forward again.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
