Mohsen you should buy a vl turbo
i really want a calais.
Good man just crazy busy been a huge year, long days every day start taking a toll though
Hows things on your end?
not too bad, also crazy busy.
inconsistent months mean im stressing, which doesnt help when ive quit the darts haha
leigh, all the nudes.
Yeah man that inconsistent roller coaster thing is super frustrating.
Good ya off the smokes man that shits no good
yeah anger has peaked though.
Saved money on smokes = More money for mods (or in your case, repairs)
approx 3 months.
just went cold the sphincter of the universe lol.
heaps of $$ saved
CONGRATS PAUL!
Mohsen is one of the few cases where I say he would be better off addicted to smoking than spending money on cars
you wait till i drop a mixtape, make a movie, die of an overdose and reappear and become rich.
So yesterday we were at a playground... I let Orlando ride his BMX through the actual equipment as no one else was there.... confidence built and he was freaking tearing it up WTAC style.
Another kid came along and I told Orlando to stop. He didn't listen and threw down 1 final lap... On the final suspension bridge (pictured below) he came round the corner from the right and ran straight into this kid... BOOM! Kid goes down like a sack of potatoes and Orlando & his inertia keep moving forwards. Orlando flies under the railing on the side rolling off back first to a ~5' drop.
Absolutely shat myself. was totally expecting mad injuries.
As he flies through the air he reaches out and grabs the bridge with one arm and somehow holds on. He hangs there for a few seconds till he stops swinging then drops onto the ground like a f**king BAWS and walks off.
PROUD DAD MOMENT
SO your saying your son was hooning with no license, had a hit and run and did a runner down a drain.
irresponsible parenting at it's worst.
should call Child protective services.
Lol I was totally getting all the "bad parent" looks
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
