Ditch racv. Problem solved. Saves you headaches if you end up making a claim.... Oh wait that's every insurance company
What headaches?
Going through a claim with RACV with the Evo X at the moment
Herald Sun tells me i need to subscribe it to read
But will make note of Hoverboard Vic laws
Speaking of accidents saw this thought it was funny, some people shouldn't have a licence
What headaches?
My headaches with were organising repairs through their people. Repairs had to be done soon or it had to be requoted or some Shit. I was working all over the place at the time so it was super inconvenient (especially considering how much they charge for business insurance) and then I got screwed over with the hire vehicle. And then was $150 out of pocket from additional charges from the hire vehicle (which isn't RACVs fault, but pretty poor form I thought)
Fair enough
I thought having the most unreliable engine ever put into a Skyline would be enough of a drawcard for him
No that would be greg's
But i see what you are getting at
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
