Up at eildon over the break, there's a queue of about 10 trailers with boats on the ramp, coming and going...
We were down by the water holding our boat waiting for our trailer to move up in the queue and this fat bogan comes up and says "How about this queue huh? Do you think people would mind if I skip past them since I'm only unloading jetskis?"
So I say "Well this queue is moving now, and people aren't going to the side of the ramp because its bogged out from flogs in 4wd's launching there, so I wouldn't"
"Yeah good point" he says and wanders off.
5 minutes later he backs down past everyone, over the rocks to the side of the boat ramp and launches two jetskis off the trailer. Takes 3 times as long as people who are using the ramp correctly... Getting death stares from everyone else at the ramp from skipping in front and f**king the bank even more. Zero fcks given, because jetski bogan
  • Like 1
So I finally tried ultra slow cooking meat...
Cape grim beef ribs in dashi miso marinade
Sous vide at 57c for 36 hours.
off the chain!
36 hours and still medium rare, (which is a trip in itself), but more tender than eye fillet with more flavour than rump.
Will post a pic when the mrs sends me one.
Do reccomend !
Sous vide that good eh..
might have to invest,
on side note,
had to wash Mrs's car tonight
car was full of jet ski's
none of them being washed that the time, just them doing selfies infront of said jet ski.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
