you don't actually think its a myth do you? like seriously its documented concrete evidence factual information that labor are hopeless with the budget.
Of course it's a myth.
If you are to look at the budget movements over the last 30 years as opposed to simply who had a dedicit/surplus in what year, you see the 2 major issues were precipitated by external causes (recession then gfc) and that after the global recession of the late 80's labor brought the budget back into line gradually and Howard merely inherited a surplus. In fact if you draw it as a line graph it doesn't actually change until well into howards reign.
Treasurers are just glorified puppets, they don't actually balance the books, they take the credit/discredit.
The guys behind the scenes doing the real work are just guns for hire and in many cases have worked for both parties. Some of howards advisors actually worked for rudd afterwards for eg
actually labor are worse and managing the budget some good info here, doesn't say liberal are perfect by any means but as a direct comparison labor run larger deficits and smaller surpluses.
http://cuffelinks.com.au/budget-time-labor-v-liberal-fiscal-discipline/
Woke up middle of night from a sharp pain. Something bit me whilst I was asleep. Had to search my room for a snake or spider. I didn't die so wasn't poisonous.
Have been multiple incidents with others being bit by snakes in their beds.
Life in the Pilbara...they don't mention this in the interview/contract.
  • Like 1
Yes historically that is accurate. But the trends are more important. Let's not forget how much the LNP love to blame labor for the current trend.
All the labor deficits were on their way to correction, as were all the liberal ones. Also that chart kinda misses the current clusterf**k.
Long and the short of it is they are no different. The thing that f**ks us up internally are the constant elections
Sounds fun. #fifolyf
  • Like 1
wtf is with morons doing 60km/h through the whole Burnley tunnel? It changes to 80 about 200 metres into it, yet three lanes of traffic manage to ignore the 3 sets of signs saying 80, feathering their brakes around 58km/h. So rage inducing.
Somehow they notice the 80 signs after the tunnel and the 60 before it, but nothing in between?
Everyone is paranoid/scared driving in a tunnel. Use it all the time when visiting the South-East burbs & get stuck each time.
God forbid you change lanes in a tunnel!
Not sure if your area sees white tails, but if a white tail gets you, you won't cop it bad for a couple of days...be like a mosquito bite until then.
lol thanks, it flared up & caused a rash around it but in the morning its all gone bar the bite-mark. Might have to search the room again tonight.
Did a geadgasket remember? What happened to VWL head job?
Sub 7.5 sec pass on a motorbike is friggin crazy, balls of steel.
Also watching 2x XU falcons run 7.2's neck and neck. Full body, over 1500kgs, twin turbo.
Over to Barry's for a metal gasket, ARP studs timing belt / water pump. A freshen up here and there.
Was looking at that RB25/30 in for sale section for $3000, seemed too good to pass up, but in the end it's lucky dip, as is any second hand engine. My bottom end was running flawlessly and I was happy with power level so the argument was if I could get out of it for a couple of grand and have the work guaranteed then that's the sensible option. Engine will be more track prepared once done and I'll look at an oil cooler / alum radiator too.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
