Bday present from Leesh = surprise Eurotrip
I realise I just pulled a Martin
But I'm trying to dodge the 65 euros or whatever that Travelex want to charge me for exchanging funds
Weak present game. Should have bought you more 88E shares
Depending on where you're going you won't need much cash
Get a Citibank debit card and withdraw euros there, is best way
Can do this without a citibank account?
Went with a Commbank card ordered online through netbank in 30 seconds, surprised I didn't think to look there first. The guy at Travel Money Oz was surprised at the rate Commbank gave me for it and said even he couldn't beat it (in spite of their poster advertising "we'll give you $100 if we can't beat a competitor's rate" - apparently this doesn't apply because a Commbank are charging me $15 for the card lol. Thanks for the suggestion!
tried my local last week, other than a couple phone cables pretty well nothing left.
well they had TV's...so they had the one I bought 12 months ago from JB for 100$ more on their clearance sale than I paid...
and we wonder why they going out of business
(they are about 1 km apart on the same road...so it not a locality thing...)
Take them to ombudsman for the lols
Two weeks too slow. Refer to my vultures comment.
Haha I remember someone talking about it, but it was good cause I got items I needed but didn't have yet like some wireless bluetooth/USB headphones, computer speakers and UHF radios.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
