years of experience make up for a degree, unless you want upper management.
we looking for a lackey for me currently, Degree a must have, ideally some post graduate.
Wonder how he will take getting told what to do by a dropout...
Would consider me? Looking for a change in direction from management in retail....
Got a degree in mech eng with vast experience, would love to make you chai latte each morning.
/beingserious
^ This, obviously depends what you do or want to do - like if you're a teacher, doctor, lawyer etc.. makes sense.. if you do arts or science :\
& yep my boss is a 'dropout' from franga too so..
Meh I still finished high school and did a TAFE course but if I could do it all again I wouldn't of bothered with the TAFE and told 18 year old Leigh to fly free
And yeah, what are you actually looking for? I do a fair bit with security and firewalls these days.. don't you do IT security?
if that was aimed at me, then yes I usually say IT Security to shut ppl up who have no idea of the niche market I'm in.
I do very large (think national ID projects) deployments of in house PKI with a few small jobs to fill in the cracks of smaller cloud based PKI deployments and our One Time Password stuff.
Used to dabble in the SSL side of business but not so much anymore.
Hoping to be the prime for our new Single Sign on solution for the region as well, but will see.
/beingserious
It's based in bangladesh for the first 6 months at local wages...lets just say we are not hiring in AU.
anyone here been to NZ? south island specifically.
Yeah.
Pleasant place to retire. Wouldn't live there. Uncle had a proper built WRX STI, spent a fortune on it... Had to drive 200kms from his house to get 98 fuel for it. Good times
NZ have really good pies too. Mutton, venison. Mmmmmm
Yeah I been there.. Spend more time at Queenstown if you were going south island thats all I can recommend.. didn't have enough time at Queenstown.
Other than that its all nature stuff really
Went all around the south island sleeping in the back of a van.
10/10 would do again, if you like getting away from things. Queenstown was by far the biggest touristy piece of shit in the country though.
So..... milage may vary.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
