Random car broken wtf problem.
Turbo howls when in vacuum (between -10mmhg and 0) and then stops at about 6psi and then sounds normal.
No, it is not the exhaust drowning it out.
How can this be a thing.
All I have done is tighten the v-band that is connected to the external gate (which is off the housing), but the problem happens at a point where the gate isn't even in play.
I don't really know what it is, pretty confident there's no boost leaks (sadly I have become very very very intimate with my charge pipes and clamps and silicon joiners and they are all replaced).
Just sounds like a big WOOOOOOOOOOOOOOOOOOO as its spooling but no sound when actually making boost. The car sounds naturally aspirated from 7psi to 25psi which is really quite weird feeling. Just very much when the turbo is spinning up, but I wouldn't say its surge because you can hear the turbo spinning *down* after you come off throttle and you are around -15/20mmhg, which is just flat out strange.
In b4 turbine blown out of exhaust or compressor wheel in intake valves, but of course both the wheels look perfect and have no play.
so you've inspected the exhaust side of the turbo after the noise started?
Sounded like a manifold leak but not ticking, just a weird... sound. Could actually be an exhaust leak from the actual exhaust because I may have hit the flex join on a few things but you know, check everything.
Fixed hose clamp going to gate from exhaust housing on turbo. You could move the band around previously so clearly it could be better sealed. Removed and new bolt after cutting the original bolt off with a hacksaw because long story.
Howly sound and better feeling engine/spool so assumed fixed.
Just makes a loud sound now. Didn't make any kind of sound before fixing the vband. Maybe always broken. Maybe not.
Dropped dump pipe and intake, had a look, spun wheels around, clearly not making contact and all the fins appear to be intact, etc.
Its more the intermittent nature of it that makes no sense, I've had leaks and manifold to turbo gaskets go etc, and it SOUNDS like that but all of those don't mysteriously stop making sound at 7psi.
I will borrow a gopro and make a video cause everything on the net seems to imply it shouldn't be possible, but hey, not like the limits of reality has ever contained this car's ongoing problems.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
