Lets put it this way... 6 months ago you were tossing up if you should get an $1800 big brake kit, or just $700 on new rotors and pads...
You chose the new rotors and pads as it was more cost effective.
These sorts of decisions aren't possible in a 1000hp build, you just have to keep throwing money at until you reach the goal, or go broke.
the chips must be crunchy and fresh, and be consistently warm throughout.
cheese should have an even coverage, and melted into the chips. alot of places use mozarella for some reason, which is a big downer for me.
best to use a sharp cheddar, as it breaks up the meat, garlic etc
the meat should be about 3mm thick, and moist.
avoid places that use meat left in a bain marie, that meat is essentially steaming in there.
and finally, the sauce.
its completely up to you, but i prefer garlic with a little BBQ. the sweetness is nice, no chilli because that shit makes me shit like an animal (on the side of the road, in parks, on simons door step)
let me know where you go.
i might come out for one lol
IN Sydney, so unless your planning another road trip.
normally go the garlic and BBQ on a kebab, thinking might add chilli on this however.
bunch of kebab sores near here just gotta find one that looks dodgy enough to be good.
(and not have the horrifically processed meat)
Low expectations
Pretty much this
I don't get the craze, I only got one or two of them to be a part of it because I'm not a hipster douchebag
You feel sick after consuming 80% of it
And it's shit meat anyway
Kebabs are better
Y'all really need to try one without processed meat and actual lamb.
greek style.
also,
TV2 up another 20% today, by lunch time.
Aka a meat platter / sampler from a Greek joint
I commit to these on the regular
You been to Kalemira? tis down your way
I just buy those meatpacks from Safeway cold food section.
Or those pre-cooked cheese burgers you can get in the frozen section.
Mmmm
pls die
greek style.
also,
20% of 5 cents is 1 cent M9
lern2invest
Ever tried those canned cow tongues? It's like budget oysters. Just don't tell your guests what it is.
Sprinkle same kale on it or something with some imitation jus drizzled on the plate.
People love to be adventurous, especially when they don't know they are.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
