jdm import car scene is slowly ending in my opinion. Seeing as majority are turbo and restricted from P-platers.
There is a move towards VW's/86's/euro cars which seem to be all the rage now amongst P-platers.
I'm okay with this - I was around the scene for that peak and ownership wise I got in on the tail end of the peak to enjoy at least a few years of it before big meets died off and before drift and stance culture faggotry came in.
There's a silver lining in it now; I get to enjoy rarity as opposed to a scene; people see my car and see something they don't get to see often or they assume I stole it and will kill a baby in a pram.
Look how popular VLs were in the day, they were everywhere and I didn't give them second looks, but now I study their condition if I see one on the road. Hoping the same happens for well kept Skylines, GTRs etc once they're all but written off. Who knows, some wealthy CEO might want to one day relive his youth and splash out on a car you can't buy easily anymore, not unlike the Aussie muscle cars from the 70s.
  • Like 1
And it's time to change cars
black maloo?
took over 5 hours today to:
pick-up trailer in heidelberg
drive home, load up car on trailer
drop off car at workshop
drive to heidelberg and drop off trailer.
Traffic was stuffed on the eastern, roadworks everywhere around doncaster and then boozebuses blocking off lanes on maroondah hwy.
lesson learnt: just pay $100 for a tow truck.
black maloo?
surely it would cost more than $100? seems cheap.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
