Very much depends where the car is stored and the temp you're starting it at
In the carpark beneath apartment complex, mine can be a bitch if it's gone down to 4 degrees overnight - talking 10-12 cranks. Haven't bothered to get the cold start tuned properly. Normal winter day after not having driven for 24 hours is about 2-3 cranks most.
I've left my car outside recently, covered in frost, started at 5am, water temp was something like ... low. Like "I should really consider the viscosity of this water going through engine" low. I.e, nearly frozen.
Started fine.
when e85 first hit the scene everyone had cold start issues.... then tuners worked out it's kinks
It's not really very hard to find out. What it needs is trial and error and most people aren't going to take their car back from the tuner and be happy to play with cold start settings. I was and I enjoy that so it was relatively easy to take the time to test but I can understand not wanting to pay $150 an hour over a course of a few days to get it bang on. Most people are happy as long as the thing actually starts. I am too, but I also had the tools handy to make it better, so I did that.
I agree with you re: 270rwkw, housemate has S15 with 265 AD08R's on it and I say "stop there it's fine". Nice, responsive, grip, excellent.
400kw peak power at 4500rpm and holding that peak till 7500 is great but unless I run drag tyres (and a wheelie bar) up HWY it won't translate to much forward momentum. It does have its benefits once you have grip mind you, i.e where 4500rpm is 4th gear.
Though it would be pretty lolsy getting up on 2 wheels on a traffic light drag. May have to go birds hunting.
If I go home right now and try to start my skyline, I know for a fact it won't start... It'll probably crank slowly, but there's no way it'll start before it runs out of juice... Tune needs some tweaking for sure now that it's winter and the fuel sits for many weeks at a time between starts.
Will be a case of jumpering it to another car, letting some charge come across and THEN going through the 30 seconds or so of going through short crank cycles trying to get some heat into the engine before it'll fire... And then once it starts, if I even touch the accellerator in the first few minutes of idle, it'll overfuel and cough/stall.
Wouldn't start at DECA, so I couldn't even get it off the trailer without a jump start :P
does a quick spray of start ya bastard deal with that?
Definately worth considering... Would be easier without the pod on it though :/ Hmmmmm I'll give it a crack, think I've got an old can hanging around somewhere.
from what I remember SYB is just ether and CO2 so should be fine
I wouldn't don't use wd40 or similar you will get a oily coating coating in the cooler as it condenses out.
actually never tried it on a turbo engine always just sprayed straight in intake/carby no idea how it would go with the long intake and AFM.
and a back fire could be much worse..
not sure about that idea now...
Abe from Havoc was talking me into E85. and if my engine runs or at least sounds healthier, then that is great. i wouldnt run it in a "throw as much boost and timing into as itll go" because ill have to back it off at 300. im considering doing a conservative 98 tune, see how it goes, find issues/weaknesses. then getting a separate E85 fuel map/tune made a la Birds.
tow truck driver last night tried to talk me out of E85 lol. complaining about how much fuel his subaru chews through and contaminating oil super quickly if not brought up to temp and just short drives or moving car in and out of driveway. plus i really hate the idea of having to bring multiple jerry cans to a track day.
you have a f**ken hatch back...how hard would it be?
shit for a track day with 180ish kw I need Jerry cans. once you have one who care how many more.
Don't know why people make a point about jerry cans at a track day, that's the easiest part of organising yourself for one
THIS.
have done it a few times. would not hesitate to do again
Havoc is a pipe fabricator... not a tuner...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
