Very much depends where the car is stored and the temp you're starting it at
In the carpark beneath apartment complex, mine can be a bitch if it's gone down to 4 degrees overnight - talking 10-12 cranks. Haven't bothered to get the cold start tuned properly. Normal winter day after not having driven for 24 hours is about 2-3 cranks most.
I've left my car outside recently, covered in frost, started at 5am, water temp was something like ... low. Like "I should really consider the viscosity of this water going through engine" low. I.e, nearly frozen.
Started fine.
when e85 first hit the scene everyone had cold start issues.... then tuners worked out it's kinks
It's not really very hard to find out. What it needs is trial and error and most people aren't going to take their car back from the tuner and be happy to play with cold start settings. I was and I enjoy that so it was relatively easy to take the time to test but I can understand not wanting to pay $150 an hour over a course of a few days to get it bang on. Most people are happy as long as the thing actually starts. I am too, but I also had the tools handy to make it better, so I did that.
I agree with you re: 270rwkw, housemate has S15 with 265 AD08R's on it and I say "stop there it's fine". Nice, responsive, grip, excellent.
400kw peak power at 4500rpm and holding that peak till 7500 is great but unless I run drag tyres (and a wheelie bar) up HWY it won't translate to much forward momentum. It does have its benefits once you have grip mind you, i.e where 4500rpm is 4th gear.
Though it would be pretty lolsy getting up on 2 wheels on a traffic light drag. May have to go birds hunting.
If I go home right now and try to start my skyline, I know for a fact it won't start... It'll probably crank slowly, but there's no way it'll start before it runs out of juice... Tune needs some tweaking for sure now that it's winter and the fuel sits for many weeks at a time between starts.
Will be a case of jumpering it to another car, letting some charge come across and THEN going through the 30 seconds or so of going through short crank cycles trying to get some heat into the engine before it'll fire... And then once it starts, if I even touch the accellerator in the first few minutes of idle, it'll overfuel and cough/stall.
Wouldn't start at DECA, so I couldn't even get it off the trailer without a jump start :P
does a quick spray of start ya bastard deal with that?
Definately worth considering... Would be easier without the pod on it though :/ Hmmmmm I'll give it a crack, think I've got an old can hanging around somewhere.
from what I remember SYB is just ether and CO2 so should be fine
I wouldn't don't use wd40 or similar you will get a oily coating coating in the cooler as it condenses out.
actually never tried it on a turbo engine always just sprayed straight in intake/carby no idea how it would go with the long intake and AFM.
and a back fire could be much worse..
not sure about that idea now...
Abe from Havoc was talking me into E85. and if my engine runs or at least sounds healthier, then that is great. i wouldnt run it in a "throw as much boost and timing into as itll go" because ill have to back it off at 300. im considering doing a conservative 98 tune, see how it goes, find issues/weaknesses. then getting a separate E85 fuel map/tune made a la Birds.
tow truck driver last night tried to talk me out of E85 lol. complaining about how much fuel his subaru chews through and contaminating oil super quickly if not brought up to temp and just short drives or moving car in and out of driveway. plus i really hate the idea of having to bring multiple jerry cans to a track day.
you have a f**ken hatch back...how hard would it be?
shit for a track day with 180ish kw I need Jerry cans. once you have one who care how many more.
Don't know why people make a point about jerry cans at a track day, that's the easiest part of organising yourself for one
THIS.
have done it a few times. would not hesitate to do again
Havoc is a pipe fabricator... not a tuner...
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
