11 minutes ago, Birds said:
It's very simple borci...
Pick a random person - see who can find more info about them - you using census (you have to hack it first) or I using social media kgo
Understand yet?
Bruh I literally don't understand your thinking here... this is just ANOTHER place where MORE of your information is stored. But here you are saying Social Media is even easier to open a credit card in someone elses name. Great... but how about you minimize the risk on your social media AND minimize the risk with the ABS. Giving them all my info is not something I'm interested in doing.
If you go back to my original point - that there are so many tinfoils worrying about the information they give to census, meanwhile many of them ignorantly give plenty of exposure to their private lives and identities on social media - it makes sense. All I'm saying is, if you are the type to worry about your info being in someone else's hands...there's more to worry about with social media than census. I will put any amount of money on it that more identities have been compromised through these channels than the ABS in Australia, and that's just identity theft, let alone the other risks of social media exposure.
10 minutes ago, dezz said:
Why are all you faggits arguing about a piece of paper I threw in the bin before taking it out of it's envelope?
http://www.news.com.au/finance/economy/australian-economy/the-outrageous-fines-you-face-if-you-dont-fill-out-census-properly/news-story/c0deab26de8ee81f44c37a9a5ab1d990
That's more of a wallet burner than 88E
You know that doesn't even come close to my 88E losses.
"But he also urged people not to spoil their Census forms by giving false information, no matter how frustrated they were."
Translation: No matter how wrong you think it is, just bend over and take it. Politics summed up in one sentence.
  • Like 1
so, what do i fill out under religion?
since noone in my family is really a practicing muslim...
also-
options- sell bmw, buy shitbox daily and use the bmw money for an intense holiday around xmas time as well
buy GTR
one of these will result with me laying in my bed crying myself to sleep, so im leaning towards holiday
i think religion is the only optional section of the census.
intense holiday? you went to Japan not that long ago. you going to US soon (not for very long).
pour money into the fourdoor and get a reputable workshop who will sort it for you, and dont go all tightassed or car will not get sorted properly. then you can stop crying yourself to lseep every night and be proud of the car you have.
yes. what is this? a car forum or something?
If anyone has any advice on buying new bed + mattress, lemme know. looking this weekend and no idea what im doing. Bed frames seem over priced for what they are (what furniture isnt), so considering looking to see if theres anything near-new being flogged off by someone.
1 hour ago, 32JET said:
Back half has HKS cast in it
Front has garret m24 cast in
Wtf?
I cant read the small plate just says garret japan in the top corner
HKS turbos are for most part rebranded Garrets with stronger actuators
Ite certainly not stock though. Check if Nissan is on the comp cover. Could also pull off your intake piping and gaze at the compressor wheel.
Bed frame means buggerall as most use shitty slats anyway
Spend up big on a mattress. Granted, a mattress salesman told me this, but it's no less true: you spend around 1/3 of your life in bed and most people spend more on their car. Not saying you can't get a decent mattress for a grand or less, but a good night's sleep changes a lot in life and you do get what you pay for. Pillow is the same deal.
If you're going to a joint like Beds For Backs, they can sell you a mattress that has a posture keeping shape and set it up for you. That does kind of make every other bed you sleep in feel shit tho.
Soft vs hard = personal preference  but hard is more supportive and your body will eventually conform to anything given enough time.
What's different about the intake comp wheel? I had a look at it the other day...
I couldn't see Nissan written anywhere either
the good ones will ahve you lie on a demo bed to see where you need support.
then recommend the correct.
oh and steel frame over wood ;)
(that last is not a real recommendation)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
