Not wheels but have used their workshop for a turbo install and they were very cheap
Something like $400 including some stud extraction from the stud doc
1 hour ago, Rekin said:
Transaction errors perhaps but I've found contractual calculations are usually accurate to the decimal point as they had to go thru approvals/legal/payroll etc
Yah for big companies
Small companies HR is just a middle aged lady with minimal qualifications with no seperate legal or payroll department.
Your too used to the big end of town Mr Rio and NBN. Vic wasterlander baller crew committee member lol
  • Like 3
26 minutes ago, blah_blah said:
Got two mates looking for 18 inch rpf1's. 1 in about 18x9 + 22 and the other set whatever sits flush on a 08 wrx
mostly trawling yahoo and jap stores. the rest i know through people.
hmmm RPF1's arent that expensive new. that would be my suggestion, as I have seen what happens to them with regular track use. and rather than getting bad gutter rash, they tend to 'snap'. someone recently go these repaired:
14358687_1118567121561327_27180578886783
1 hour ago, Leroy Peterson said:
first ones i don't mind, but from the pics pretty much won't fit over the brakes.
I just tried on some of these at otr with the 9.5s on the front +30 clears brakes by a bees dick, only problem is cant get silver they can only get flat black. Still looks good though just need to decide if I want to go black again
i saw a pic of the concave's on a falcon and wasnt really sold on the look. and they dont look like the most friendly wheel in the world for brake clearance. anyway,
work wheels. T7R 19x9.5 +25. $2,020 plus postage http://www.jdmconcept.com.au/part/work/emotion-t7r-set
not sure what that price compares to the concaves.
http://www.jdmconcept.com.au/part/work/mco-racing-type-cs-set - 18x9.5 +22 for 1900. you can then run my 275 18's for cheap ;)
problem is, a lot of the falcons with rims don't get the right sizes so looses it's potential most BBS LM style look aids on them but mine pulled it off i think
11219326_10153527809028779_4849204322059
Concaves are $1800 for comparison and OTR said they'd swap my tyres over for free for me from my BBS's.. not really sold on the work T7R would rather concaves over them I think.
18s look too small on falcons, look at those 19s ^ just about right.
Need to paint the D1Rs black so no one can see them properly.
Theres that falcon on bags that was wrapped like an aqua green colour... White D1Rs spoiled it.
I also thought 18's were too small for gloria, but reducing tyre width made heaps of difference. Also good luck try to sell wheels without tyres. People too tight assed about it. Its like rego and selling cars.
Which is ridiculous because most tyres that come with rims are dodgy shit or worn out anyway lol
People never seem to like putting in effort for the unseen hero components of a car
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
