Just now, Birds said:
They are more luxury performance tyres, like the Continentals, where they will perform well in dry and wet but you also get less road noise than cheaper tyres.
and if I remember correctly he whinged like a bitch about road noise for like a year
3 minutes ago, joeyjoejoejuniorshabadoo said:
121 mph trap speed @ circa 1550 kg inc fat-ass driver.
your move...
it's common knowledge that heathcote speed trap isn't accurate, mine was a few mph higher than all the other tuned 5.0s too
your move :P
edit: it's true, NT05s were noisey af
Edited by UNR33L
Which is why I always maintain it being undervalued
That oil price will inevitably be sky high again one day as the finite resource diminishes and even unconventional plays become worth a truckload. The market hasn't factored this in yet, hence minor OPEC shit gives a small push. If the rest of the world is banking on renewable energy offering an oil solution and you hedge against it...correctly...you'll be winning.
370 sets would take a while to get through
unless you had a 370kw 370z
  • Like 2
31 minutes ago, joeyjoejoejuniorshabadoo said:
INVO's are probably better street tyres for your power level though - will last like 5 times as long too
I did still have the skyline when I bought them
glad i didn't get a chance to fit them and gift the new owner a fresh set
  • Like 1
Not for a few more years at least. The OPEC announcement won't change a whole lot it just restored some confidence that something can be done to hopefully limit the Saudis and Russians trying to undercut the Americans. I think the Saudis are in trouble soon...
But this unconventional thing is a double edged sword. The more that is found and is profitable, the less finite the resource is. So looking 5 years down the track, I don't think itll get back to $100 a barrel. Everyone involved is looking to retire before then.
As for undervalued... Otto energy is exploring in 3 different locations, their great bear section of Alaska is next door to 88e and is further ahead in exploration but worth 4.5cents still. Due for some results in dec-jan. If it's not amazing news 88e will take a big hit.
12 minutes ago, HEKT1K said:
Move on pls Birds
My priorities have changed
I'm sorry that the theft of your vehicle hit me harder than it hit you
#insurancejob
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
