1 hour ago, Leroy Peterson said:
Not for a few more years at least. The OPEC announcement won't change a whole lot it just restored some confidence that something can be done to hopefully limit the Saudis and Russians trying to undercut the Americans. I think the Saudis are in trouble soon...
But this unconventional thing is a double edged sword. The more that is found and is profitable, the less finite the resource is. So looking 5 years down the track, I don't think itll get back to $100 a barrel. Everyone involved is looking to retire before then.
As for undervalued... Otto energy is exploring in 3 different locations, their great bear section of Alaska is next door to 88e and is further ahead in exploration but worth 4.5cents still. Due for some results in dec-jan. If it's not amazing news 88e will take a big hit.
OPEC announcement is just an example of how much people will move on the smallest of news. Off that alone you've seen 10% intra week. When big news hits they move big, which gave us the ten bagger last time. With that kind of drastic movement, a dollar within 5 years is no more unrealistic than expecting the company to succeed. There is plenty of big news to come, but the long term ace up my sleeve for this one has always been the price of oil currently being in a slump because of the Saudi's greed and pride, which is eventually going to screw them over when they realise how cheaply they've f**ked off their second biggest export (first being female oppression amiright). 88E's resources are so far looking like a conventional/unconventional hybrid...profitable at levels much lower than your average fracking operation; it was actually said not long ago that current levels would be profitable, let alone a return to glory, which IMO is inevitable. I won't go into huge detail here, but 88E's resources are looking way more attractive than most unconventionals including neighbouring Otto. If Basinki is right we are in the absolute sweet spot for drilling.
Basically, I'm happy that you don't expect the price of oil to return quickly...I'm counting on everyone else to think the same way, as that is holding the SP down long enough for me to accumulate and rely on increases I predict will come later on and steadily drive up the SP. Long term, the share is a great prospect to me, but my 200%+ short term profits have been made from knee jerk reactions of pessimistic investors turned optimistic, so bring on more!
Early impression of the Federal RS-RR vs shagged out AD08R - a fair bit less road noise on these, I'm guessing mostly because my rears were nearly bald before I replaced. Regardless, that's still a plus for the Federals which I expected to be noisy. I know there's an improvement in noise from RS-R to RS-RR.
Gave a squirt on slightly damp road and she stuck well, but new sticky tyres will do that. Need more dry road and more time.
A big variable to test is that I've gone from 265 to 245 because I read these tyres run wide. They probably do a little, in that the 245 appears to sit where a 255 AD08R would.
Scratch that - some serious road noise above 60km/h - hoping it fades with some run in. Can't hear it unless music low/off and it IS holding 1st and 2nd on post-damp roads no problems, which is super for $180 tyres. See how long they last...
was chatting to Richo re the rs-rr on the weekend
apparently they don't heat cycle well, give them a good thrash on the track and they go off in a couple sessions.
friend was running one of the R32 GTRS on the weekend on rs-rr's as well and 2 track days in and they gone.
I don;t think I would be running them personally.
one I think i'm going to try however is the Nankang  NS-2R ,
they running them on Starr's BMW and the feedback so far has been nearly as good as RS3's for 120$ a corner.
next time I do a day will throw a fresh set on to try.
maybe your car was just tuned on a hub dyno and doesn't make much power
and yeah starr's bmw did a 1:40 around winton too n/a don't forget - pretty good!
Edited by UNR33L
  • Like 1
Most of my racing happens on the street anyway, but will see at least one track day before a change. When are we at PI next?
next year..hoping to be back by then, will depend on date.
really want to go back to winton tho, as not been back since the crash and need to prove a point
That you're capable of doing a warm up lap?
Oddly, the noise of the federals went away above 80 so it's a resonance between 60 and 80. Was silent at highway speeds which is a relief...can actually go long distance without irritation.
On a wet but not raining road it held well, kicked out very slightly full throttle in second, but it was very predictable and no spin in 3rd. I'm happy with that for a dry tyre. Will try some twisties on the weekend to see what the sidewalls are all about.
Shit I didn't even start a warm up lap...that started 20 meters after the crash.
but sooner or later one must return to the sceen of the crime.
done sandown a few time and mallala just not been back there.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
