1 hour ago, HEKT1K said:
If you aren't a massive nerd it's fine bruz
Get over it
This
1 hour ago, UNR33L said:
I'm talking more about business for productivity not home net
True, best most of our customers have is like a telstra 50/50 or 100/100 which cost em an arm and a leg
buuuuuuuulllssshhhiiitt
you are talking about computer games and we all know it
get some better customers...
Multi 10G connections for our smaller data centers 100G for larger and our own dark fiber across the Atlantic.
Data center vs small-medium sized businesses :P no wonder
is it ironic that some of the best domestic internet access is in the country? Nick is in Wallan and has amazing internet...
also that feeling when you take a few days off work then you wake up sick on the first day of leave. so shit.
16 hours ago, Rekin said:
All internet providers use the same cabling/infrastructure if you are in a NBN zone.
Think of isps as owning a lane on a freeway. Although a multi-lane freeway has been built, if dodo has only paid for 1-lane it will get congested at peak-hour. Whilst Telstra could have 3 lanes to itself.
I no dis. so its pretty much a race to the bottom in terms of pricing.
I have TPG ADSL 2+
It's fast enough to stream movies and it's cheap / unlimited.
Given video games are for children it should do me for at least the next ~10 years
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
