3 minutes ago, blah_blah said:
Gee whiz how long has the engine been built for Birds?
I think Greg dropped off his motor a few weeks ago and it's already nearly done
If it lasts as long as it's taken to get built I'll be happy :rofl:
To be fair, until Greg has a functional and lasting engine, as far as I'm concerned his engine build started several years ago and still isn't done...
  • Like 1
Touché
In saying that the last engine blew becuase someone told him it would be a good idea to use an external gated standard manifold
38 minutes ago, Daz said:
How are you going to have e-fame when it's built by someone other than Racepace?
GTS-T is RacePace tuned so I get the e-fame benefits of being a RP customer and not being one :D
I actually want to upgrade my rear rotors to DBAs now too.. just to match the front - OCD?
Want to paint the rear caliper black while I'm at it.. too bad I'm lazy AF and working on cars takes too long
4 minutes ago, Birds said:
Pfft who needs rear calipers at all
I know right, but dat OCD
15326301_10154104776233779_5989463439700
Also, come wax my car m8
Actually, if I polish it should I tape up the stickers? srs question
Edited by UNR33L
3 minutes ago, Daz said:
Wow I'm surprised the gtst hasn't fallen apart yet
lol
Very happy with my RP tune and will prolly head back there for a touch up soon. Can't fault their work myself - the only reasons I went to Barry for the R is that RP had trouble fitting the car in and then I started dreaming of 26/30 awesomeness, which Chris isn't a fan of. Love dropping in on Barry now though, it's like seeing family I've been there that many times.
R33 GTS-T is also the most reliable Skyline ever...they are notoriously difficult to kill without the aid of power poles or thieves haha
Yes polish is microabrasive, so will eventually damage/fade the stickers, if not the first time.
IMO get a professional to do the polishing (easy to fk up and hard to master) and then wax it yourself (hard to fk up and easy to master).
But then I'll need to pay final inspection 2k
If you wanna be sure to pass the scrutiny of those walking past your car with an electron microscope in hand then you probably fork out for FI
For everything else, there's ma...some other detailer.
16 hours ago, Birds said:
Probably
Head is back though, which he's porting and polishing now
So machinist isn't an excuse anymore haha
Should see the fuel system he's putting in the 34R :O
Reckon you'd get free lunch from Baz?
1 hour ago, Birds said:
lol
So your gtst must be low powered and running a power fc then
  • Like 1
I'll win the bet
Whether he coughs up or not is a different story
I'll just steal his Saturday chicken from him
  • Like 1
24 minutes ago, Birds said:
I'll win the bet
One way to find out.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
