1 hour ago, HEKT1K said:
I suppose if I'm gonna pay an electrician to fix it, I should just spend the same money and buy 10 new ones
Good luck when they boycott the TV brand you were considering, scab
8 minutes ago, blah_blah said:
Director's just delegate anyway ammirite?
Yup ATO always have issues
100% forgot to text you on Saturday
Spent the time earning another csgo rank lol
Pat's dad can
Pat pls respond
People who repair technology today are cheap-skates and my dad has had enough dealing with annoying customers.
He fixes industrial machines for companies now. Companies much easier to deal with.
25 minutes ago, UNR33L said:
Picking up some tyre warmers for the track days today - serious business now
A mate just binned his R6 track bike on a low side after spending a month preparing it
Handlebar torn off, fuel tank crunched
Take care
Take care
That's the beauty of supermoto, if you crash it you can just pick it up and on your way again :P
Although a 600/1000 sport track bike would be great fun to have too
I guess the warmers will be good for not putting a heap of heat cycles into the tyres every session.
Edited by UNR33L
lol @ Nissan V8 supercars garage sale this weekend. put up some sample photos on facebook, nek minnit photo album turns into Drift Sales. people from all over the world asking for prices and if stuff has ever been raced with before. someone tagging Todd Kelly for a price haha.
People wanting to buy individual (used) pistons and heads and build a motor lol because those Nissan V8 heads are going to bolt straight onto your 2015 Nissan Patrol.
  • Like 2
I do a similar thing when I go out to group dinners / lunches
So scumbag but meh until table pay tech arrives that's the way it's gonna be little darlin
When we first started up eSign the original company I worked for in AU before we got bought out a bunch of times..
we needed a bunch of Sun gear, as we were a new company we didn't have credit terms with them so had to pre pay.
as it was a time sensitive thing, the CEO had the receptionist use her work Amex to pay for them.
as a small benefit we got(and still do) to keep the points on the cards to use ourselves,
250,000 points in one day. damn.
Still in the red.
Land auctions this week, no guarantee it will go down. Next announcement should have quantitive results, so less likely to decrease price unlike previous announcements.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
