2 hours ago, dezz said:
How does foxtel justify not providing surround sound in 2016, especially with what they charge ...?
I'll keep the platinum package if they drop the price enough.. But I all honesty most of it is complete shit... Sopranos, Seinfeld sons of anarchy etc on constant reruns, the same movies over and over again, most of them not even good movies...
Sport they've got me because of MotoGP, f1 (although after never missing a minute of coverage in the last 10+ years, my interest is fading with the current state of the sport) and to a lesser extent AFL, but everything else I watch on there is more often than not from boredom and staying on something I've flicked through randomly, and already seen.. Sopranos is a perfect example.. Seen the entire series 10+ times and have the set on DVD, but still watch it on foxtel if I'm bored..
Nature docos I don't mind, but almost everything else they show is either old, shit, or I can download it before they show it anyway, without ads.
Shoe program
I ditched the second room, movies and HD.
Like seriously what the f**k is the point of watching a docco about Hitler full of footage from the 40's in HD....
My tv watching is 90% docos so SBS on demand / YouTube is plenty for me
23 hours ago, Birds said:
Forget the prices, check the buyer and seller ratios and unit ratios...those sellers are climbing hard and we've just hit 4.3...once again...no news is propelling this, only rumour and expectation.
Like I said, get out before the rats do. There are way too many profit takers in this stock for it to rocket up with anything short of truly awesome news. It may end up with a new floor but it's not going to be 4.5, it will be 3.9 or 4 cents etc.
You either play the game ahead of them or you the miss tidy profits to be had in the meantime. Or you're a long termer locking them in the bottom draw...
Jordan fades back...
What should I get my boss for a xmas gift? I'm not sure what he drinks other than beers though.. What's a normal gift scotch / whiskey? I got no idea as I don't drink the stuff.
Is there a beer pack you can get from Dan Murphys with like a few different nice beers?
Something like this I guess..? even though some of the beers are shit
https://www.danmurphys.com.au/product/DM_500959/world-class-beer-collection
Edited by UNR33L
to have a wank, obviously.
i cancelled foxtel when they lost the EPL
Get him something he can easily regift to someone else
  • Like 1
f**k TV
This.
Cactus gift for everyone.
Pulled out 50% stake off 88E yesterday at 0.044 for break even. Will keep an eye on it over the holidays and may buy back in same volume if it dips around 0.035.
3 minutes ago, Leroy Peterson said:
This.
Good man
But IMO increase the volume if/when it falls to the 3s
Organic accumulation of shares; pretty much the opposite of what panic sellers do when they sell at the bottom and have to buy in higher
4.2 at the moment... Its not too late to sell.
TV2 getting close to rock bottom... Might be worth a small packet for some potential doubling/tripling (they have contracts but lost trust of shareholders).
Anywhere there is a loss of confidence amongst shareholders that is not also lost on you is an opportunity to make money.
Shareholders are on the whole the most hypersensitive bunch of knee jerkers...if you can acknowledge and respond to this accordingly, keeping your eyes on the fundamentals, then you're playing the game from the sidelines while the fools squabble.
How about a bottle of Macallan Whisky. So he can be a boss like Harvey Spectre as that is what he drinks in Suits
  • Like 1
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
