Agree on the new age exhausts. Cannot stand the way DSG gearboxes/engines sound!
Im just saying, for my money, id be looking elsewhere. I like my hot hatches to be a little less bland and a little more boy racer.
20 minutes ago, emts said:
Disingenous...waiting for modifications is hardly a state of being broken
Also wager being a VAG product that vehicle more likely broke down on the drive home
You might like the new Focus RS and the dolled up A45s
Yep! You are bang on! Love those two. One problem with each. Ford, have the worst post sales service I've ever encountered (used to have an xr5 bought new). And the AMG I don't think has a manual.
When you comparing a 33 GTR seating position to a Falcon yeah (don't forget it's just a family sedan), I came from 33 GTR as well felt the same way but got used to it after a while.
Fark it's hot, VB come at me
Nah compared to our 5 series. They have an excellent seating position. Nice and low. Long way back. Super comfortable. Ill actually be selling it in the next month or two because my wife stopped using the wagon.
dat BMW re-sale duration + value
I buy mine at the low end... the one in my avatar was 17k. Plus some repairs. Was on the road for less than 25k at a time when people were asking 30k+.
To its credit it's an awesome family car and isnt terrible to drive. Just needs a bit more go and stop and it would be perfect.
Its also been incredibly reliable. No break downs since we fixed it up (2 and a bit years now). Not at all what i expected.
2 minutes ago, joeyjoejoejuniorshabadoo said:
I'd take a golf R or audi RS3 over any boy racer looking shit any day. If I'm going to spend 60 large on a car I want to look like an adult not a child.
Yeah but you're all about appearancez hamich
Some guy already wants drug money for his well kept 33R series 3 in the for sale section. I don't think he'll get 55k for it, and it really doesn't look that special, but if people are starting to ask that much for a clean example then it's a sign of things to follow on from the obscene 34R prices. Mine without an engine is insured for about 26k.
inb4 Leigh's switch to a Falcon was a financial downgrade?
  • Like 1
So that 33. The way i read it, its done 150k kms. (Two gauge clusters worth) think thats too much.
But if this was a genuine low km (say 75k kms) car i can see someone paying it.
Eh, mine was a rusty bucket - was from the snowy parts of Japan apparently and the salt on roads screwed underneath a bit, basically didn't get it checked out properly before purchase being a youngen, mechanically was fine apart from unusual extra turbo lag which Trent couldn't explain without taking turbos out, but surface rust on the rear subframe etc made it hard to sell, only got like 20k for it 5 years ago, barely had many people come and check it out. Buyer bought it unseen flew from SA then put it up for sale again for 26k over there after a few months, not sure how he went with that.
The GS will go up in time no doubt, rare as and eventually won't be many around - who knows if I'll keep it for the long run or sell in another few years but at the moment happy with it and wouldn't want anything else for what it's worth.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
