2 hours ago, Daz said:
Birds 88e cap raise?
You still in?
Yeah I missed opportunity to dodge that a day or two ago...
It'll open down, prolly fall to the cap raise price then we'll recover as per usual. Not a big deal for me as I'm long term, but would have been nice to pick up more shares for cheaper.
  • Like 1
So jetstar do japan domestic flights apparently... If i had of known that before i booked my qantas ticket i would have taken the bullet train instead.
Then becoz of usual 2hour jetstar delay, qantas changed my entire itinerary for some unknown reason. Instead of direct to melb from Narita, had to go via brisbane. So 2x stopovers requiring switching from domestic to international and having to sprint to each flight due to delays.... Arrive in melb 5 hours after original expected time. Miss my lift so now skybus + train + drive. F**k jetstar and f**k flying. Ill just jetski to japan next time.
I had a similar one years back, QF ticket turned out was code share on Vietnam Airlines.
Worst flight I had,
3 seats across center row, myself on aisle lady on far side and her 2 kids sharing center seat..1 vomiting milk on take off was a bad sign
Think 1/2 the people on the flight had shopped at the Queen vic market 3 hours prior to take off and brought on carry on...lots of aromas.
hour into flight some-one blocked the smoke detector in the toilet in front of me to use as the communal smoking room for the whole plane.
add in some disgusting airline food
the aroma by the end of the flight was horrific
Changed travel agent after that one.
I have learnt to check all flights that I get quoted now.
Off the plan are stamp duty free anyway IIRC, so the stamp duty exemption will only really assist new home buyers looking at established properties, in which case they will miss out on the FHOG because IIRC that has to be a new dwelling.
Will probably drive up demand a little bit once it sets in, but my logic is that in the interim there could be some cheap (<450k) established home bargains to be had as first home buyers wait until July 1 to purchase.
buy now with 120 day settlement and still get it
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
