ahh that Life Support show used to crack me up.
"people in wheelchairs gets sympathies from juries.... dead people don't"
Sometimes I wish there were more Afrikaner people in english comedy.
  • Like 1
If you're home, a perfect excuse to watch Contagion
Fun fact. Remember when I was real sick a couple years back... The virus I had was actually the one from this movie
2 minutes ago, joeyjoejoejuniorshabadoo said:
Just saw a mint bayside blue 34r with black TE's... Was all good until I saw the plates... O'CONOR
I hope he dies
seen pics of this floating around..just why...
However would love if he trolling everyone and it was a body kitted GT like in the film..
or maybe it's this stolen one cropping up...
https://www.autoevolution.com/news/fast-and-furious-4-nissan-skyline-stolen-6756.html
I hope he dies
Won't happen until you take him for a drive in a Porsche
  • Like 1
18 minutes ago, UNR33L said:
dont be ghey. then you'd say you dont drive it enough, then you'd sell it to buy bike becoz cheaper insurance/fuel/running costs.
1 hour ago, UNR33L said:
so you say that but for same money...
https://www.carsales.com.au/private/details/Aston-Martin-V8-2006/SSE-AD-4604668/?Cr=8
your in a price range there that gets you a whole bunch of nice machinery,  and would you get that?
Mate bought one(new 2014or15)  and only kept it 6 months as it was just so clunky.
when smae money gets you C63, M3 and a bunch of others, not sure if I would be going a nissan.
  • Like 2
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
