yeah they do an estimate based on previous usage every 3 months, only do a real check every 12 months or so and then do a top up.
I had the opposite in the past when I started traveling for work, usage dropped massively and ended up with a decent credit.
2 hours ago, HEKT1K said:
Went to a travel agent for the first time today, to see if I was missing out on the best deals etc
Travel agent: "Where's Skopje?"
nope
And when you been waiting and do a follow up with them forgetting to call you back with their deals.... "I forgot"
Just got a gas bill more than 3x of any bill in the last 12months, the charges go all the way to step-3 off peak.
Only gas appliances are heater and hot water. Heater is disconnected electrically and was serviced in winter. I was away from home 4 nights a week from Jan to Feb, then overseas for a month.
I'm reading that sometimes gas companies to 'catch-up' bills if they get their estimation wrong?
I'll check the gas meter when I get home, but if the figures are similar, ain't shit I can do?
Went from 27MJ a day to 147MJ a day. No leaks that I know of...
Old man had the same issue where his bill tripled in one month. He just didn't pay it until they came out and did a reading. Turns out they got their measurement units confused and over calculated it.
36 minutes ago, Mohsen said:
also how the f**k do i set up boost Ts?
you need a boost gauge.
cut your actuator vacc line in half. put boost tee on eitherside of cut vacc line. Set to like 1-2 turns off lowest setting. drive. note down boost. adjust accordingly.
44 minutes ago, Mohsen said:
boys boys boys.
whos got a metal intake pipe to suit rb25 laying around? trying to get the stag to rip massive VL spec doses lmao
Got one here if you want to buy.
3 hours ago, Mohsen said:
boys boys boys.
does anyone in this forum have anything to do with cars these days?
its only you and hamo who dont do cars no more.
I commented on something on facebook and the notorious Krysztof got butthurt. Am I getting him confused with that guy that is a living punchline in VWL?
done. 30psi TONIGHT
the question is, will it flutter like central park does if you walk through it with some bread?
how much. will pay top dollar for something dodgy as f**k.
a few of us still do, but it feels like were all in exile.
maybe one day we will unite and power will be restored.
  • Like 1
4 hours ago, Mohsen said:
boys boys boys.
Use K&H bumper black spray (the one for 80's black bumpers) and it looks like a stock part works a treat
  • Like 1
I might when the Kia Stinger GT is released as that think will need maybe exhaust/boost/tune
totally getting me one
yeah i saw some photos of them they look pretty decent actually
im thinking of upgrading but then i feel its a waste of money so meh.. probably gonna end up buying something lol
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
