Macron v Le Pen
This should be an interesting indication as to whether the world is gravitating towards a sharply nationalist agenda or simply rejecting the political status quo.... Particularity given the recent attacks in France
well that's essentially the first part of my point, refer "gravitating towards a sharply nationalist agenda"
Considering this is a country that's had it's fair share of terror related incidents in the last year or so, it would stand to reason that nationalism could be viewed in a more positive light by those directly or indirectly affected.
I don't think you have to be nationalist to fear the ramifications of open border immigration from war-torn countries, even if that is traditionally a trait of nationalism; Le Pen like our Hanson could be seen as the lesser of two evils..."I don't like xenophobes and racists, but terrorists are much worse"
so speaking to someone i know who is a JP at Springvale police station... older Vietnamese man comes in and says his car has been stolen. apparently was in a minor accident, guy who he hit (not sure who was at fault) said they had no insurance but will take the car to a panel beater and get it repaired. So the man handed over his keys and the guy drove off in it never to be seen again.
It's easy to get on the *facepalm* train with this one, but man, I felt really sorry for the dude. Super friendly old man, who isnt used to dealing with the scum we come across and witness every day, and he gets reamed thinking someone was doing something out of kindness. f**k this gay earth. and the dude is probably too honest to lie about the situation to the insurance company.
f**king swindling scumbags.
fine... make it "gravitate towards political parties that use nationalism as a core theme of their political rhetoric"
That's better...
Sincerely,
A member of the Linguistics Nazi party. We're pro-semantic.
  • Like 2
But then he gets to keep the thief's car...sounds like a fair trade to me.
I like how Dell can mark-up their laptops by $1000 just because theyre in the "business" section of the website. I can seriously buy an Asus or Gigabyte laptop with better specs in every department, or a "home" Dell with the same spec for half the price. But it would be an "Inspiron" then not a "Latitude" model. bah Latitude has been using the same architecture for like 10 years.
38 minutes ago, Odium said:
After only 680 pages? Rookie mistake, last thread was > 2000 pages
To be fair, last thread had real estate, unions and Captain Will as topics
Think Rimon may have even been in there
Business laptops have additional features such as docking capabilities etc. (nohomo)
Just quietly...if you came into my interview with an Inspiron I wouldn't hire you no matter the specs...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
