So anticipating the need to purchase a new laptop, unless I can get this one fixed for a reasonable price, what's the best way to retrieve the data from the hdd in this one, without opening up the new one and putting the drive in there obviously...
/If you cant get into the bios at all thats kinda shit, warranty out? run with no battery but plugged into the wall charger?
simple cheap hard drive sata to usb caddy (or cable) will get your files back
something like this
https://www.mwave.com.au/product/simplecom-sd326-usb-30-to-sata-hard-drive-docking-station-ab73084?gclid=CjwKEAjw85DIBRCy2aT0hPmS1jkSJAC1m9UvU-gOpPUTUhvYc-OzAMTIZiiaG32l2093bcvRMWI04RoCJ4vw_wcB
Edited by UNR33L
  • Like 1
Two year warranty, haven't found the receipt buy searched this thread and found I bought it around September /October 2014, so about 7 months out of warranty.. That's why I opened it up, no warranty to void... I'll give em a call see what they say... If it's not a ridiculous price to fix it, I'm happy to keep it, hasn't really given me any issues
Seen weird things before by battery causing problems, if its HDD or RAM that's f**ked you should still be able to get into bios easily
Probably your mainboard though, wont cost that much to get it replaced if they still got em
Edited by UNR33L
I'll get one of those cradle things Leigh posted before sending it anywhere... There's not a whole lot of shit on the drive as I keep it on an external drive connected to my network, but still wouldn't mind backing up what is on there
true that
but they do generally lsit tow ratings for a reason...and when they drop them 700kg for this car prob should take notice.
and worst case scenario something happens insurance company can mess with you hard core.
(also seen cops on the Hume 3-4times in past 2 months directing trailers into the weigh bridge.
11 hours ago, UNR33L said:
arent they rated for 2.3tonne?
mine tows sweet as but mines just a dirt bike so meh.
FPV 1600kg.
R33gtst with fuel just over 1400 kg,
lightest possible trailer I could find was 350  most tandams circa 600 - 700
23 minutes ago, emts said:
FPV 1600kg.
Yeah dunno why officially it's 1600 over the standard turbo 2300kg, you'd assume it'd be right.. it's the same chassis with BETTER brakes, maybe it's just a 'FPV brand is better brah' don't tow! thing?
I wouldn't be worried about it that's for sure
Edited by UNR33L
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
