Underquoting laws came into effect today
Half the prices are now missing from realestate.com.au app ?
Never seen so many listings saying "contact agent"
Dishonest cunts
  • Like 2
I'm gonna wager the RS6 has at least 300kg on the XR6 turbo and would need an extra 100hp at all times to keep up beyond the launch.
Put it this way...if my goal was a 10 second car, I know which one I'd be starting with. You'd pull it off well before you got to the purchase price of the Audi, which is a comfortable sleeper at best. And by sleeper I mean the electrical/mechanical problems that await you.
My own view of most expensive Euros is that they become largely useless once they are outside their warranty periods and outside of VIP faggotry or baller lyf P players, which is one reason they die in the ass hard for resale.
Stock the rs6 is a high 11s car, with nothing but a tune it's low to mid 11s, the packages after that give you 900-1000hp.
200kg difference between them.
I mean a current gen golf r/s3 will go high 11/low 12 with a tune, exhaust and an intercooler.
Got a source for RS6 quartermile times? That sounds optimistic to me for the V10 model. Regardless, none of that negates my point that the same results can be achieved for substantially less in a probably more reliable and cheaper to repair way.
Also struggling with 12 second flat from R/S3 with just that. I'd believe breaking into the 12s...but am feeling a turbo swap to get a high 11 out of them. They would need another 100kw at least...
Got a source for RS6 quartermile times? That sounds optimistic to me for the V10 model. Regardless, none of that negates my point that the same results can be achieved for substantially less in a probably more reliable and cheaper to repair way. Also struggling with 12 second flat from R/S3 with just that. I'd believe breaking into the 12s...but am feeling a turbo swap to get a high 11 out of them. They would need another 100kw at least...
Granted. It's probably cherry picked run but high 11/low 12 should be possible with basically any run if your best is 11.7
Wow if that is the stock turbo...are they laggy or just amazing tech?
F6 seems to do similar stuff with flash tune and exhaust
I imagine life gets very expensive once you go beyond that for the Golf
Mid 11s seem to be about the limit I reckon for a street driven, street tyre, street surface RWD car.. I thought about modding mine further but already can't get off the line on the street :P
On-roll races ftw! not that I do that anyway these days, too old and responsible.
Do like a good 3rd gear 200km/h powerskid though
Edited by UNR33L
gets expensive at this point.
the tunes for these just seem to be to lean them out massively so it's not really a if but when scenario.
Yeah but not like you've ever run a real decent set of tyres on it...
Flat-brim friend who went from pulsar to S15, to wanting a GTR and then wanting a Golf... Got off his P's and then bought a HSV lol.
Now post videos of him and friends doing prinny runs on weekends.
The circle of life continues. I only know one other Asian with a V8 commodore. What happened to TurboDragon anyway?
So what power does a stock Golf R make?
And what power does one with a tune, exhaust and cooler make and cost?
Damn so many golfs on the street these days they will just cream me i spose lol
Ive been in a launched Golf R and it was quick from a launch but died down afterwards
They are a big stock turbo compared to what they tune it to. In "stage 2" trim you are around 250kw at the wheels. So it doesn't really hit hard until 3000-3500.
yeah I have, big fat NT05s with massive sidewall lol
still liked to get squirly
Edited by UNR33L
Mid 11s seem to be about the limit I reckon for a street driven, street tyre, street surface RWD car.. I thought about modding mine further but already can't get off the line on the street [emoji14]
Even mid 11 isn't usable on the street for a rwd car, as soon as you give it anything in 3rd or below you are doing power skids.
250awkw with a cooler zort and tune wow. How does the DSG hold up
Should have bought the wife a Golf R not an Evo X
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
