250HP at wheels from APR site...not KW.
Edit: yes this is a GTI but they claim the same for all the E888 motors so the R S3 blah blah whatevers
That's not a mk7 and the R and gti are not the same motor. The R has a much larger turbo.
With the correct graph, Apr state 354hp at the wheels for the mk7 r (264kw)
Is it possible to retrieve data from the SSD? backed up the SATA drive with the dock, if I can back up the SSD I'll be set..
After that, will doing a fresh install of windows solve my boot issue, or am I gonna have to take it back to centre com?
My prediction of 88E falling post spud (a nothing event) came true
But I did not predict a small spike occurring today over a nothing update from DW essentially saying "everything is going fine"
The short term reactions to long term investments never cease to amaze me. The buyer behavioir in a nutshell is "everything went as expected in the day to day operations of a company today, time for me to buy in".
14 minutes ago, Leroy Peterson said:
hey Leigh, I have one these lying around if you want it cheep for one of your many motorbikes.
https://ecliptech.com.au/shift-i/
No need brah I got one of these bad boys laying around too
https://www.mxstore.com.au/p/Trail-Tech-Suzuki-DRZ-RMZ-250-450-Silver-Vapor-Com/75-301?gclid=CjwKEAjw3KDIBRCz0KvZlJ7k4TgSJABDqOK71ezh5hqTPUGrwJC3S8UyMNZoUCoNCzm7o7_rqEGYQBoCCx3w_wcB
If shares were easy to predict everyone would be a millionaire
how do you install it?
my current shift light is not giving me much joy
If everyone were a millionaire our dollar would be so inflated that your Falcon would be worth a few mil.
Reactions are usually easy to predict, events not so. Knowing the former can give you a bit of an advantage.
Brah call MSI tech support, sounds pretty bricked if you can't get into BIOS. Probably needs a motherboard replacement done by one of their techs.
Or if you are baller enough just buy a freshie, get your MSI one fixed then sell it when you get it back.
Ric must be a real POS - how often you actually use it? :P don't you get a laptop through work anyway?
Not often lol, it's pretty clunky but does the job
I have an X1 Carbon for work
1 hour ago, dezz said:
Yeah I'll call em just wanna back everything up first if they're gonna wipe it in the process..
Any way to backup the SSD?
If it's physically removable then yeah you can put it in a caddy / usb cable and grab your stuff.
If it's part of your motherboard soldered on then nope (MSI probably have ways though) (or if it would actually boot you can run software off a USB to clone the disk.. but yours won't boot so yeah..)
Edited by UNR33L
/remove home made porn before someone else sees it
That stuff is stored on a separate drive
Is that another dock I need, or are they the same pin set up as a normal hard drive...?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
