250HP at wheels from APR site...not KW.
Edit: yes this is a GTI but they claim the same for all the E888 motors so the R S3 blah blah whatevers
That's not a mk7 and the R and gti are not the same motor. The R has a much larger turbo.
With the correct graph, Apr state 354hp at the wheels for the mk7 r (264kw)
Is it possible to retrieve data from the SSD? backed up the SATA drive with the dock, if I can back up the SSD I'll be set..
After that, will doing a fresh install of windows solve my boot issue, or am I gonna have to take it back to centre com?
My prediction of 88E falling post spud (a nothing event) came true
But I did not predict a small spike occurring today over a nothing update from DW essentially saying "everything is going fine"
The short term reactions to long term investments never cease to amaze me. The buyer behavioir in a nutshell is "everything went as expected in the day to day operations of a company today, time for me to buy in".
14 minutes ago, Leroy Peterson said:
hey Leigh, I have one these lying around if you want it cheep for one of your many motorbikes.
https://ecliptech.com.au/shift-i/
No need brah I got one of these bad boys laying around too
https://www.mxstore.com.au/p/Trail-Tech-Suzuki-DRZ-RMZ-250-450-Silver-Vapor-Com/75-301?gclid=CjwKEAjw3KDIBRCz0KvZlJ7k4TgSJABDqOK71ezh5hqTPUGrwJC3S8UyMNZoUCoNCzm7o7_rqEGYQBoCCx3w_wcB
If shares were easy to predict everyone would be a millionaire
how do you install it?
my current shift light is not giving me much joy
If everyone were a millionaire our dollar would be so inflated that your Falcon would be worth a few mil.
Reactions are usually easy to predict, events not so. Knowing the former can give you a bit of an advantage.
Brah call MSI tech support, sounds pretty bricked if you can't get into BIOS. Probably needs a motherboard replacement done by one of their techs.
Or if you are baller enough just buy a freshie, get your MSI one fixed then sell it when you get it back.
Ric must be a real POS - how often you actually use it? :P don't you get a laptop through work anyway?
Not often lol, it's pretty clunky but does the job
I have an X1 Carbon for work
1 hour ago, dezz said:
Yeah I'll call em just wanna back everything up first if they're gonna wipe it in the process..
Any way to backup the SSD?
If it's physically removable then yeah you can put it in a caddy / usb cable and grab your stuff.
If it's part of your motherboard soldered on then nope (MSI probably have ways though) (or if it would actually boot you can run software off a USB to clone the disk.. but yours won't boot so yeah..)
Edited by UNR33L
/remove home made porn before someone else sees it
That stuff is stored on a separate drive
Is that another dock I need, or are they the same pin set up as a normal hard drive...?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
