8 minutes ago, UNR33L said:
I know Chris we've had some interesting facebook conversations not so long ago
I was trying to find a PM I had with the dude but no avail. I remember him asking if he could ask out my ex...seemed like an unnecessarily polite request from someone I didn't really know? Hard to believe someone like that is a wanted crim now?
He used to do a bunch of track days till he had the usual GTR pop.
was good value.
I'm assuming there more to it as he def did not seem that f**ked up.
might just have got proper slavic drunk and talked too much shit to wrong person!
8 minutes ago, dezz said:
Don't think walkinshaw do kits for $27..
I assume you have like 5-10k on it.. get out and get the charger :P
Or enjoy the 2-5k it'll be worth shortly!
I'll get back in after the inevitable drop down to .04c
33 minutes ago, Leroy Peterson said:
I'm up 45% but will hold.
Famous words for many poor people. .
Good...make or break. It's a spec stock. Sure there's money to be made in the interim, as I've proven, but the end game is on the horizon.
How much do you have in this? Initial investment?
I've been growing it as I've managed to work my way back out of financial trouble. Which makes my CGT goal a bit difficult to determine. Ideally hold on until aug/sep.
Average purchase price was down to 4.2c at one point, now it's 4.4c.
Not enough for wilkinshaw supercharger, but enough for a cheaper and better alternative.
1 hour ago, Birds said:
That didn't answer my question - how much you got in the share?
http://www.bulletcars.com/superchargers/toyota/1-uzfe-v8-engine-supercharger-system.html#universal
Toyota UZ Eaton supercharger kit worth.
PS - goddamn Harrop charge a few bitcoins for their supercharger kits. Would be worth more than most VE's and VF's in 2 years time.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
