Not me, I'm out for turbo doll hairs $. If someone buys my GS for the right price will jump into an STI for something different.
Harrop chargers are so nice though :) same deal with their brakes etc. big doll hairs but good performance
Edited by UNR33L
When you consider how much 88E has ramped up (50%) in just a couple of weeks based off fairly expected news announcements, you have to believe that with a joint venture or buy up deal on the table this thing would go from cents to dollars in a matter of days
Had my Dell laptop for over a week now. Had so many issues with it out of the box.
- Selecting Standby in the start menu would shutdown the laptop (fixed)
- Selecting Shutdown would put in standby (fixed)
- Laptop hangs at the Starting Windows page only when restarting (im still trying to fix this...)
- Laptop takes same time to boot as my old laptop, which was a f**king lean machine once I'd tampered with it, but pretty poor form.
- Has AMD gfx card, but doesnt use it for anything (fixed, had to install AMD drivers and software then specifically assign programs to the secondary gfx card)
- comes with two sets of audio and two sets of wireless software/drivers, but uninstalling the unused ones disables the device completely. dont make no sense.
- a whole bunch of other shit that I've fixed but have forgotten.
I'm contemplating a clean install, but worry will cause more issues than fix. Especially since it doesnt have a DVD drive built in and Dell supplied all the backup drivers and OS on DVDs. yay.
1 hour ago, UNR33L said:
Clean install win 10 brah.
All of that is just software related issues / bloatware
ive removed a lot of the bloatware.
Also, has to be win7. I need to put the Zoltan unit on win7 too, it runs like a pig with win10.
4 hours ago, dezz said:
Dell sounds like a great choice..........
it never was a good choice. But its what the boss wanted, and he's paying for it.
Edit: oh yeah, tried to use the laptop on a TV last weekend, f**king no audio through HDMI. HDMI/TV not listed as a device. Has something to do with the Intel inbuilt graphics drivers.
And also that stupid Dell Audio software. Turn off artifical sound enhancements, then when you close the window it turns them back on again. And theres no fix for it. It uses Realtek drivers, but if you uninstall Dell Audio then the sound stops working. FFS.
yeah used to be easier, was basicly a mobo perm attached to a screen.
but you could swap HDD/cpu/ram/Graphics.
now it's pretty well all onboard so what you see is it.
but makes them significantly thinner and lighter but less fixable.
Shame you can't just build laptops like you can PCs...or can you?
this is why I wanted a metabox. Standardised chassis, pick your components and they set it all up for you. Then you know exactly what you're getting and can save money by removing shit you're never going to use... Like Bluetooth.
This is the way Dell used to operate, to a degree
I picked every component in my Inspiron 12 years ago...sound card, gpu, cpu, screen type, hdd size and speed, ram speed and size, bluetooth, wifi (when it was an option), minimal bloatware. Back in those days they gave you a myriad of options to choose from and it wasn't vastly more than the cost of building things yourself. I remember the equivalent spec laptop from HP/Lenovo/Acer was 3k+ and my Dell came in just over 2k.
Not likely, but you can always disable your bluetooth controller anyway.
If you like our company can set up your laptop for $200ex / hour.
Also nice gif, good movie.
Edited by UNR33L
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
