Not me, I'm out for turbo doll hairs $. If someone buys my GS for the right price will jump into an STI for something different.
Harrop chargers are so nice though :) same deal with their brakes etc. big doll hairs but good performance
Edited by UNR33L
When you consider how much 88E has ramped up (50%) in just a couple of weeks based off fairly expected news announcements, you have to believe that with a joint venture or buy up deal on the table this thing would go from cents to dollars in a matter of days
Had my Dell laptop for over a week now. Had so many issues with it out of the box.
- Selecting Standby in the start menu would shutdown the laptop (fixed)
- Selecting Shutdown would put in standby (fixed)
- Laptop hangs at the Starting Windows page only when restarting (im still trying to fix this...)
- Laptop takes same time to boot as my old laptop, which was a f**king lean machine once I'd tampered with it, but pretty poor form.
- Has AMD gfx card, but doesnt use it for anything (fixed, had to install AMD drivers and software then specifically assign programs to the secondary gfx card)
- comes with two sets of audio and two sets of wireless software/drivers, but uninstalling the unused ones disables the device completely. dont make no sense.
- a whole bunch of other shit that I've fixed but have forgotten.
I'm contemplating a clean install, but worry will cause more issues than fix. Especially since it doesnt have a DVD drive built in and Dell supplied all the backup drivers and OS on DVDs. yay.
1 hour ago, UNR33L said:
Clean install win 10 brah.
All of that is just software related issues / bloatware
ive removed a lot of the bloatware.
Also, has to be win7. I need to put the Zoltan unit on win7 too, it runs like a pig with win10.
4 hours ago, dezz said:
Dell sounds like a great choice..........
it never was a good choice. But its what the boss wanted, and he's paying for it.
Edit: oh yeah, tried to use the laptop on a TV last weekend, f**king no audio through HDMI. HDMI/TV not listed as a device. Has something to do with the Intel inbuilt graphics drivers.
And also that stupid Dell Audio software. Turn off artifical sound enhancements, then when you close the window it turns them back on again. And theres no fix for it. It uses Realtek drivers, but if you uninstall Dell Audio then the sound stops working. FFS.
yeah used to be easier, was basicly a mobo perm attached to a screen.
but you could swap HDD/cpu/ram/Graphics.
now it's pretty well all onboard so what you see is it.
but makes them significantly thinner and lighter but less fixable.
Shame you can't just build laptops like you can PCs...or can you?
this is why I wanted a metabox. Standardised chassis, pick your components and they set it all up for you. Then you know exactly what you're getting and can save money by removing shit you're never going to use... Like Bluetooth.
This is the way Dell used to operate, to a degree
I picked every component in my Inspiron 12 years ago...sound card, gpu, cpu, screen type, hdd size and speed, ram speed and size, bluetooth, wifi (when it was an option), minimal bloatware. Back in those days they gave you a myriad of options to choose from and it wasn't vastly more than the cost of building things yourself. I remember the equivalent spec laptop from HP/Lenovo/Acer was 3k+ and my Dell came in just over 2k.
Not likely, but you can always disable your bluetooth controller anyway.
If you like our company can set up your laptop for $200ex / hour.
Also nice gif, good movie.
Edited by UNR33L
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
