9 hours ago, Birds said:
On the open wheeler note
https://www.carsales.com.au/private/details/Ariel-Atom-2004/SSE-AD-3899997
Why on earth would you need that much power...sounds awfully close to F1 kw/kg territory
no mention on the fact the chassis was cut up and rewelded to new dimensions to pass au kit car rules.
or the fact I don;t think it has finished a track day without blowing something up.
have seen in the pits a few times years back and closer it gets the scarier it gets...
Dezz when you are installing windows 10 make sure you delete all your existing partitions on your hard drive, then create a new partition for the full size (it'll be empty) then install on that.
(Probably self explanatory & do it anyway just checking you're doing it right and not installing over the top or 'upgradeing')
It's a lot of money for an experience... And that's about it.
Again, would go for a Caterham. At least they are proper registerable and the duratec/zetec motors are known quantities with info and spares.
Probably wouldn't have done what you just said actually... Left it downloading over night and didn't check it before work this morning.. Can I still do the partition now or do I need to start again? Laptop was wiped and windows 8 reinstalled, I've only put shit like utorrent and ipvanish on it so far..
Would give a 620r a solid go.
It will wipe what ever is on the hard drive currently, so you boot from windows 10 usb stick > install windows > custom / advanced > you'll see your hard disk and it's partitions, delete them all so it's empty, unformatted, then click new > accept the default size (it'll be max hdd size > click on your new partition > install > wait 30 mins > done
You now have fresh windows 10 install with no other crap left over from windows 8 etc. Laptop will be faster, better stronger.
There'll be a youtube video somewhere of it surely, but my instructions should be good enough
Edited by UNR33L
f**k lots of steps involved.. Think I just upgraded when I first went to 10.. But laptop is pretty much empty at the moment so I guess I'll do it... I think the os is automatically installed on the SSD and the sata drive is just for everything else and porn...
I'll read your instructions when I'm at home and not balancing on the edge of a switchboard.
It's pretty easy, and it's worth while doing a 'fresh' install over just an upgrade.
Yeah install OS on the SSD ofcourse, you can add/format the Sata drive in later for your porn in windows disk manager
Edited by UNR33L
If I do this partition shit will I still be able to install 10? Was under the impression it scanned your computer for a legit windows licence before letting you update to 10.. If I've formatted completely, won't I lose that?
Nah it still works, key is embedded in the hardware
13 hours ago, blah_blah said:
Can confirm Gregs car is an absolute beast. id be surprised if any rwd skyline on here could beat it from.a dig. Birds pls respond
You just can't climb in the ring with Ali cause you think you box
  • Like 1
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
