I drove a vn wagon that happened to have internationals on it for a while. Towed pretty good, but there was rub as the suspension squatted (pan hard bar pushing the axle sideways). Made an ok tow car with heaps of room for tools in the back.
Edit, forgot CSH.
3 hours ago, HEKT1K said:
see a lot of Maybachs out your way Birds?
Not as many since we signed that petition to stop them parading up and down our street so often
I think I might actually buy these wheels...
https://page.auctions.yahoo.co.jp/jp/auction/u160682457
1200x900-2017090300006.jpg&key=5dbb2312e62968a2317e1c29d2133da1a830ae0ed6939c1243aca19e02da458a
Edit, on second thought it's not that much more to buy brand new and customise. Plus jesse said too much risk for secondhand wheels that price.
When you're sick for a few days at the start of the week, get a medical certificate but the doctor puts the wrong dates on accidentally (forward a week).. give to my employer and they ask me to get it fixed to correct dates.. call Doctors office, wait 3 hours for a call back.. get told yes but I'll have to come and pick it up, finally convinced them to FAX it through.
At what point was me wasting time worth it?
/Friday Rant
Do they make you get a med cert? My workplace never bother with it
I always thought of them as pointless when they can be obtained so easily. My opinion is if you're well enough to get a med cert then you're probably well enough for work. If you're too sick to work, why make you do the unrestful thing and go out to get a med cert?
Because the doctor gets to bill Medicare for your visit to get a note to say you aren't well, the ones where you go into work and then go home because you aren't well and they still want the medical certificate are even more meaningful.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
