work for said company.
Options are a promise of a share at a set price given to staff to aid loyalty
These will usually be available to you over a period of time at a set price.
so you only profit if you stay with the company and the company goes up in value.
Eg as part of our annual review at previous company we were eligible to options.
we might be given 1000 options that vest over a 4 year period, so we had access to 250 per year. (some might be a single issue at a set date others might be over 10 years depends on time and offer.
say the issue price was 30 dollars.
in 12 months we could access 250 options at 30$
if the share price was 40$ now this was a great thing. I got 2500$
if the share price tanked and was at 20$ it was not worth excising the options and if they get to the expiry date prior to getting back over 30$ then they were worthless to us.
we had people who were issued options at the top of the dot com boom at 200$ plus.
1 year later the share price was 8$  lets just say they were never exercised.
  • Like 1
4 hours ago, dezz said:
How does one acquire said options?
88EO is the stock code for the current options
They can be traded just like shares, or converted into shares if you pay the 2 cents per share or whatever it is to convert
Options end in March, so steer clear.
CPH and MXC are doing well overall IMO. I don't have much invested, but good time to get in or top up I think. I also got the run in on BYE but not sure if it will go much higher, had a successful drill that goes into production in 2 months I think.
3 hours ago, dezz said:
So if no one exercises their options at 2c, fair to say they ain't finding shit down the hole..
Being offered at .007 doesn't seem too promising
Few reasons people wouldn't exercise their options:
- they can't afford to. Many people spend all the investment money they can on options to maximize their leverage, so that if the company ever does take off massively they just borrow money or pour more cash in to exercise them and end up better than if they'd bought heads. Borrowing money if the company hasn't taken off yet is not very wise.
- they don't have faith in the company to come through with goods
- they haven't spent that much on options and already have heads anyway
- they forget about the expiry date
- they trade options just like shares with no intention of ever exercising them
You can still get gardening leave if you resign and are currently working on cases, depending how your firm approaches that...wouldn't be difficult to sell information to opposite counsel
don;t you just get told not come back and paid out?
Any-one with customer account info here doesn't make it back to their desk to work after a resignation letter.
safer that way.
no idea what our current non compete contracts are.
I've legacyed in from years back with a support role.
well...
some-one has agreed to buy a bunch of shares at 2 cents when they are trading at 2.8 cents if the people running the business don't want to purchase them..
so think to yourself why people running the business would not want to buy shares in their own company at 30% under market value.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
