6 hours ago, Leroy Peterson said:
Yeah I don't think a single modern toll Rd in Australia has actually switched to free.
Still shits me the transurban CEO is on like $2.3mil a year and pays more tax than the company itself.
This guy received his invite to the VWLBC yet?
Got a huge corporate tax bill to pay?
CAAAAAAAAAASH TRAAAAAAAAAAIN
  • Like 1
59 minutes ago, Leroy Peterson said:
I thought Qantas losses were offset by Jetstar profit...
If it's a tax consolidate group then yes. Likely given that Jetstar is wholly owned by Qantas.
I'm working at a substation tomorrow along Narre Warren - Cranborne Rd, I haven't been there in years, I remember it being the only non farm land thing along the road for kms. Tried finding it in Google maps today and can't find it. There's only houses and shopping centres. It's endless.
Pretty decent growth suburb - 11% from memory.
Vacant land is practically non existent and old houses are being snatched up for current and future subdivision. Fountain Gate is a massive draw card, as is the Monash cutting through the suburb.
Will be what Rowville is now in about 5-7 years.
Especially with Cranbourne filling out farmland with estates left right and centre - would not want to live down there with insane congestion on the way. Much needed freeways down there.
Berwick and Endeavoir Hills have also gone nuts. As the more established and gentrified suburbs, they're boosted by Narre's growth the same way Narre is by Cranbourne and Clyde.
Works in citylink to tullamarine roadworks expect +6 months to go.
Finishing the Monash widening will be great too. Though, I might be moving north towards the end of the year :(
If 88E and crypto kick off, plus higher interest rates, might be able to get a place lolololololol
Things bout to get interesting for 88E with 3D seismic commencing and impending reopen of IW2.
Gym guys talking about Crypto was bad enough. With 60 minutes doing a report on Crypto and telling viewers whether they can make money on it or not, you couldn't pay my to invest right now...
lol @ auscoin goons too
I never understand with the huge corporate job cuts, why they are all done at once instead of slow reduction over time to offset the liability to the point they might not need to slash as many
to show a big change to "hopefully" impact share price in a positive way.
or you can do it they way my old company did and just pick a few low hanging fruit and then realize 3 months later that they lost a whole bunch of skill sets.
eg for one product they decided to merge it with another, so started by removing the entire dev team for that product.
when to product team 2 and they said no we cannot add that to our project due to good reasons x, y and z.
SO then hire new devs to maintain first product and they take 6 months to get their head around code.
rinse and repeat. multiple times.
or get ceo 1 who goes we need to merge everything, so support can support all products not just the ones they trained in, 18 months later new ceo, no we need to container all products and have specialists, 18 months later new CEO  and guess what!!!
but each needed to come in hot and have a new strategy to hopefully boost shareholder confidence...none ever did..
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
