21 minutes ago, Leroy Peterson said:
https://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?listingId=487434773
Now THATs an investment. Signed by Pol Wolker himself. Owned by Frankie Muniz apparently....
It's actually a pretty cool looking car, if it had smaller wheels and more low
call fake....
the real one had invisible brake calipers
Image result for fast and furious jetta no brake calipers
some-one is trying to make a nice profit on it tho
https://carbuzz.com/news/the-fast-and-the-furious-jetta-just-sold-for-a-pathetically-low-amount
Yeah someone brought up the brakes thing.... Who da f**k knows.
I still don't get the supra thing.... I know the guy who bought Aarons old wide body shell. Gearbox and motor will set him back more than the the body and a full restoration will.
so the OEM brakes on it were too small so they put one of those fake big brake covers on it to hide the tiny ones.
some-one (smartly) removed it at some stage
so yeah it is the real car, it's just of all the cars in the show that prob the lease attractive to own, 2l NA auto....
https://www.ebay.com.au/itm/2x-Universal-Auto-Car-Wheel-Disc-Brake-Racing-Cover-Silver-Q9N7/183369226178?epid=23008171393&hash=item2ab1a857c2
At the time of the movie though, all the Leroy types were fawning over it cause the JDM was too mainstream
Safe to say a combination of rarity / collectable and those movies are responsible for JDM sky high prices. No surprise that the vehicles with the most gained from it are those featured as heroes in the movie...34R, Supra and RX-7. S2000 has also seen a good comeback on pricing. Then again, Jap classics like Hakosuka, RX3, VL Commodore and 2000GT did it just fine without movie power behind them.
  • Like 1
2 hours ago, emts said:
call fake....
Apparently S2000s are front wheel drive ?
I do agree with them about it being nicer back in the day when a dramatic scene didn't involve crossing buildings in a car and the excitement came from who would win a race and who was cutting who's tuna lunch
If the script was smart enough someone would have commented on the booty call but instead we got "burger and fires for 2.95"
Am I still a Leroy type? I stanced out the Gloria last weekend. Didn't even get many efames :(
Am I still a Leroy type? I stanced out the Gloria last weekend. Didn't even get many efames default_sad.png&key=60edf0cfeb1b5687d093da59e19dcb4bc4ca5078c255acb1c3a47ac6adc5cc5e
Not enough filter.
That’s why.
  • Like 2
Not enough filter.
That’s why.
The wraps only come in one size... So I guess anyone that doesn't like wraps and gets embarrassed ordering a footlong?
Speaking of footlong... Might try to get a massive weiner in me this weekend. Chapel St is shit, but I'll make the effort for a giant hotdog
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
