Again not even close to the issue. That's just you projecting your own views onto the situation.
They didn't ban them for women's rights
Hardly
The thing wouldn't exist if Islam wasn't an oppressive religion
My original point was: any leftist objecting to the ban on burkas in Switzerland is effectively, inadvertently standing up for a tool of oppression lol
  • Like 2
You realise that by saying "It's a slippery slope what you allow and don't allow" you are perfectly validating one of the major reasons people say it shouldn't be banned....
And as for hiding a knife in a hijab, that's an absolute nonsense reason... unless you also think we should ban trenchcoats, suit jackets, non skin tight jeans, backpacks, suitcases, sweaters etc etc etc.
There are 100 places to hide a knife on a person, none of which specificly require the clothing of any religion.
As a security guard what would you rather have to search / pat down, jeans or a giant cape?
a hijab is not a giant cape.... in any case you then have those crazy things thag buddhists wear, big jew coats, latvian orthodox hats, etc etc etc...
Hardly
All religions opress their followers, that's basically the point of organised religion... Control via opression.
I agree with you that it's archaic, pointless and opressive, but end of the day it's their choice. If it makes them happy then good luck to em.
None of which completely conceal a person's identity
right... because it's important that we see a terrorists face before he detonates a suucide bomb so we can arrest him afterwards right
None to the point that Islam does...it's reputably the worst for gender discrimination
I can assure you that given a choice of which they would practice if forced...most non-Muslims would choose Christianity, Judaism or Hinduism over Islam any day!
The overwhelming majority of muslims are not like that at all. That's just taking extreme examples and applying it to the whole.
Honestly all Christianity is just as whacky if you try to follow the bible to the word
The irony that you just took a mild example and applied it to the whole
Edited by HEKT1K
  • Like 1
That's pretty easily attributed to the fact that Murdoch is a Christian...
just wow
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
